OK all. Saw a very old post of this similar topic. I posted very briefly there but it had a lot of chit chat back and forth. So nice new clean post time.
This might be worth doing for anyone wanting a almost stick looking setup like mine.
Gtx3076 .82 low mount internally gated. Rest of specs are in car section on profile.
Car made initially:
just over 300rwkw @ chequered (status tuning)
285rwkw @ Avo turboworld
250rwkw @ jjm turboworld.
All @ about 18psi
Below are my changes in flow. And my dyno chart now running bout half a pound less boost (call it same boost for arguments sake.
http://db.tt/lawVTzKg
http://dl.dropbox.com/u/13400788/IMG_20120415_093132.jpg
I've linked to them as they are larger than allowed. Nice n clear to read.
Let me know what you think.
Edited by ShiftyTys
  • Replies 87
ive seen a 20kw gain starting @ 4000rpm from GT to GTX, although the GTX was running 2psi more boost.
Post up the results if you have them. I haven't seen a back to back result that makes me think that the GTX range is a step forward in this framed turbo.
Yeah definitely dyno differences very apparent. That proves what everyone already knows.
It leaned out heaps with just the manifold changed which was a good sign there was power to be made.
Cost bout 800 for the porting including shipping both ways. Not too bad for 50% flow increase.
Status dyno was more generous than the attached dyno. Showed boost and power coming in earlier.
Drives like a monster though.
So how is that even comparable?
Because - It's not.
It was related too a comment made... :domokun:
Sorry mate I no longer work at the place anymore, it was on a patrol, we got the GTX30/76 back in October, took off the GT30/76 that was on our test truck and put the GTX on, from 4000 it started at 20kw, @ 5500 before the power died it was only around 12kw gain, for a 1500$ turbo it wasnt worth the gain, it was worth adding meth injection instead of the GTX. Though from a factory upgrade id go a GTX.
Edited by 51NNA
hows the traction at 300kw? haha
Also do you have a build thread?
Edited by 51NNA
Horrible traction. Lol. Second is useless on boost without throttle control. 3rd is iffy lol 3rd feels like I'm floating. Wants to break free.
Nah no build thread. Didn't think anyone would be too interested in my little upgrades and plans at the time!
haha awesome! im aiming for 300kw for my drift build, currently only 200kw, it spins 3rd alright but on the straights i cant pull 4th without it dieing :unsure:
Any build threads interesting :yes: ile probly make one after im finished doing everything, but i do plan on keeping the stock manifolds :woot:
Haha nice. Aren't build threads meant to be during the process? Lol. Well this may be an option for you if u want to keep standard manifold. They tell me e85 internals + more boost should see me at about another 50+ rwkw no worries.
thats what im going for :yes: 1000cc injectors, 300lt/h pump probly hypergears ss2 or g3 turbo and see what happens :rolleyes: and Ile start the thread once i have all the parts ready to bolt on :whistling:
Edited by 51NNA
Oh how wrong you were lol. People would love to see a thread on your car mate, especially if you have back to back on porting the stock manifold.
Hmm. What's involved. What I did. When I did it. What difference it made at each point. charts where possible? All in one massive post in new thread??
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
