  • Replies 43
My car is not an auto. My best time is 14.8 on Sat I was trying for a consistant 15.1.
What do you think about a 2nd gear start I've thought about it . might give it a try this Sat.
I could have cut my throat when I broke out!!!!! I was up against a Wrexxy who dialed in 14.6 and I thought I had a good chance of beating him
182km/h is AWESOME!! You should have enough juice to run an 11 sec pass, and 1.9 60' is excellent, did you run slicks? What were your 660' times and mph?
Hey Squizz, can you let us know about Benaraby. A few of us were talking about going up there, if there's an import meet I would be keen to run the Zed. Is it full 1/4 mile?
TTZ sorry haven't got my time slip (as mentioned it was stolen with some of my other gear only have the ones from earlier in the day but my friend has his and I ran against him will see if he still has it....we weren't too impressed with the times so he probably disposed of it :) . I was running street tyres but got a awesome launch sorted.
Nismo_Boy.. .were you there?
I didn't see the R13. Not that I knew what I was looking for. I also didn't see cam till he ran his first run at night. I think we missed a lot of things :)... But we seemed to be in the stands most of the day. Can you post some pics Nismo_Boy?
hehehe......benaraby.
Imagine Willowbank...
Now remove the buildings and infrastructure. Place a drag strip (1/4 mile) in some bush not far from Gladstone, Qld.
Basicly a piece of bitumen, in the bush with timing equipment. What more do you need?
It is fairly well supported by the Gladstone, Rockhampton & Bundaberg people though. Is fairly surprising the numbers they get, and the Import meet will be well supported by the Gladstone guys, and Squizz and the Kaos crew.
Check out www.benarabyraceway.com
but don't expect too much. :)
I didn't see the R13. Not that I knew what I was looking for. I also didn't see cam till he ran his first run at night. I think we missed a lot of things ;)... But we seemed to be in the stands most of the day. Can you post some pics Nismo_Boy?
yeah I was there. The R13 got there around lunch time, it was next to Cams little group, I would post pics but the computer shop took Jpeg off mu computer :) and I don't have a windows disk to put it back on:(
Took the words right out of my mouth...
Guest sir calais
Heres some more info on benaraby raceway http://www.benarabyraceway.com/
..... you've got to admit Benaraby has improved from how it was this time two years ago. Least now theres grass on the mound - actually least now theres a mound. All they need now is a decent road to get in there.
Dam I may have to put the TEIN's back in incase I need to turn hard at high speed.....OH crap :eek: I sould them, what am I going to do????? Does sound interesting though......bit like one of those witches-hat slaylem style of events I spose
ok ok ok...lets just say it is still a very good regional track. At least it is full 1/4 mile, better than some. besides the people in Ipswich, how many of us can say they have a decent, legal place to have fun on?
Hey Boosmeister, you thinking of going up for it? Benaraby drags that is.
I will be in Airlie Beach from 18th Oct for a week so if it is around that time I may take a side trip....only problem is it is a long way from home and I'd hate to wreck my holiday if I broke something......especially when the car may be getting sold:eek:
    • Yeah it is always worth testing and balancing actuators out of the box, just set the pressure regulator on a compressor very low (eg 5 psi) and increase it slowly to see when they both move.....unfortunately while you may be able to adjust the length of the actuator rod to minimise any difference, the actual pressure they move from is not adjustable so you need a well matched pair. And yes, the VCAM is probably contributing; the earlier in the rev range they come on boost and the slower the revs build (I think your demo was in 5th), the more you notice it.  Driving at WOT through 1st, 2nd, 3rd etc you will probably never hear it as any shuffling starts and is over super quickly
    • oh they were with that motor, you need to remove the engine to change the spark plugs (don't have to, but it does make it easier)
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
