Hey guys up for sale is my 97 r33 skyline *incomplete*
engine, gearbox and computer are already sold as well as front guards bonet headlights and front bar.
Interior is 98%complete and the rest of the car in good nik.
Looking for $1000.00 for the shell as is
May be interested in parting It, pm me for more details :)
Edited by offset33
https://www.sau.com.au/forums/topic/397940-97-r33-skyline-incomplete/
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
