Hi all,
After spending many hours reading thru topics on here I have decided on a set of GT2860 -9 turbos for my R33 GTR but still have one niggling problem I'd like to throw to you experts out there......and that is the issue of that shuffling you get with larger BB turbos.
Now, there're plenty of topics that talk about it but a lot of them stop half way or don't quite confirm a solution. The three main solutions appear to be:
1. Keep all your factory plumbing, especially BOV return a and balance piping
2. Weld a balance pipe between the two manifolds
3. Weld a divider pipe into the "twin turbo" collector pipe.
Could anyone who has had this problem please let me know how they went about fixing it. Am hoping for solutions and comments from those who have actually dealt with the problem first hand....
I was orginally going to go for -7's that apparantly are so close to stock performance that they don't shuffle....but now that I'm going for one step up from those I'm thinking we'd be back in the suffle zone.
Thanks for your time guys ;-)
https://www.sau.com.au/forums/topic/398415-rb26-twin-turbo-shufflesurge/
  • Replies 126
Ah ok excellent - sounds good. And yes, that's a good point - I had R33 N1's on it at one stage and they never shuffled either althought technically, it has more to do with how fast and how far down low the BB cartridge makes the turbo spool up rather than just size etc etc.
But either way - sounds like I'm in the clear with the 9's
And yep, I'll be keeping all my intake piping for now anyway..
Thanks for the quick replies peeps ;-)
If you can increase the amount of air the engine can ingest at that point I guess they wont surge as badly, or just slow the compressor down by reducing the exhaust velocity? I would expect timing, especially valve timing could play a part in fixing the issue.
Tuning does without a doubt play a part.
That said, I've had two -9 setups no surge on a 2.6
My -5s on 2.6 will surge ONLY on a 4-8 degree morning in the hills, loaded up in 5th @ about 2300rpm from what i can remember. basically such a rare occurrence it doesn't bother me.
I had the same thing on my 32GTR with 2530's. Solved by changing down a gear :)
I've done heaps of divided turbo pipes, they do work but having done so many I also found a trick with the divider plate.
I leave a small section of the front turbos air path in plated, it allows some of the front turbos air to swirl around into the rear turbos path.
A customer of mine who is a fluid scientist type guy explained how making the front turbo swirl around the inside of the pipe before merging with the rear turbo helps promote a lamina flow and draw the air away from the compressor housing thus reducing the shuffle.
The mod does seem to improve the issue on all the cars I've ever done one for.
Can't hurt to give it a go.
Ah damn, so there's probably a 50-50 split of people who've experienced shuffling and those who haven't with -9's
From everything I've read it would appear that the GT2860-9 turbos are on the very limit of wanting to shuffle. We're approaching winter so I guess some of these very "well working" turbos will shuffle a bit down low with the far more denser air.
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
