Hey looking to put some good high end brand name audio in a V-series sedan. Kinda like along the lines of B&O (bang & olufsen), Harmon Kardon, Mark Levinson and so on.
Was looking at high end Rockford Fosgate/Alpine but they're a bit too common.
Any ideas?
https://www.sau.com.au/forums/topic/398464-high-end-audio/
Sorry to fart in the post chris
DLS , ARC are mid range at best DLS splits ok subs no
ARC top of the line subs ok
And alpine and rockford top of the line are made / designed by one of the below companies (mids and tweeters) crossover parts are where a lot of the cost increases , some caps cost 25 bucks retail for top of the line direct from company
So its easy to dump 300 bucks just on a crossover if you go OTT and package it nice
You dont always have to spend a mint to get good sound that sends chills up your neck, the install setup makes a big difference , a 200 dollar splits sounds just as good as $2000 when installed average and tuning is off And i can vouch for chris he will do it right , maybe a dozen shops in oz i could say that about !!
My choices for hi end SQ speakers ( a sample )
Dynaudio, Vifa, Morel, Image dynamic horns / subs ,SEAS, polydax and audax (same company ) peerless , hybrid audio , Scanspeak
B&O, Linn, Mission, Thiel & Wilson all use SEAS brand drivers
Vifa is also used in B&O, Mission, Paradigm & Vandersteen
Boston, JBL, Klipsch, Polk, PSB, Snell, Sony & many others use POLYDAX
Dont overlook Hertz top of the line ,new pioneer SQ stuff , MB Quart 3 way splits , GoldSound mids and small woofers , Orion HCCA subs are beasts in the right box and can sound good still
Earthquake "holeEshit "subs if you want some monster spl bass in a big car , to much for skylines due to weight
You can buy the parts from a few companies way cheaper and a expert installer can design the crossover to exceed just about anything you can buy off the shelf since it will be for the car/speaker relation response , or run active xover tri-amp power
There are a few other brands but the cost and availability turns insane $20k for a pair of 3 way splits and require massive mods cutting steel and panels to fit and a thousand watts per channel available for dynamic range
Like having a f1 car but able to be driven daily , in case you need the power lol
To give you a rough idea , mine is near 7,000 watts max power , 2,000 to front speakers alone
some of the brands above come in 100,000 dollar plus home speakers !!! and one is used to recreate sonic booms for space craft / shuttle tiles when it was being used
And then you need amps , processor and headunit to make it sing
https://www.sau.com.au/forums/topic/398464-high-end-audio/#findComment-6328212
I drove an A8 LWB fully loaded with the full B&O sound and it was incredible!! All I've got in the car now is four speakers and two tweeters. It's good but it has me yearning for clarity bass and all round great sound, like a theatre inside my car. I don't care for doof doof or epic amounts bass. Would like to add more speakers.
https://www.sau.com.au/forums/topic/398464-high-end-audio/#findComment-6331719
More speakers doesnt make better sound ( unless its a THX theatre or concert )
The goal should be attention to detail in the install, quality drivers , lots of dynamic ( damping factor of 250 or more @ 4 ohms ) clean power , and possible time alignment with drivers and processors if required , tight fast bass from a 8 or 10" in a custom box designed for the car, driver and music source
Some of the best systems use 5 speakers , 2 tweeters, 2 mids and single sub
quality cables
Clean amp power ( digital amps make bucket loads of power but not as clean as class A or A/B )
Audison bit one or ten processor ( digital in and out if you have the amp for it)
Alpine imprint
Audiocontrol
a few others are decent but the ones above excel
the speakers in most cases are imports ( voided warranty buying overseas in most cases) and lots of install costs ( local shops dont cut it Only top installers with skills and tools to do it right) dont drop the car off and expect it back the same week !! To do it right takes time dont rush em
and set the rules ( cutting ok not ok , hidden system or show ? , music tastes , source ie mp3, dvd etc , $$$ you can spend on it ) and buy a great alarm/ immobilizer first !!! And insurance If you dont have those items already
Remember some of those tweeters are 4 -5 inches or horns a foot acrosss and only fit umder dash or heavly modified locations
Expect the best part of 5-10k +to buy and install all of it to perfection and at least a week of time solid
in the end you will be amazed , its like someone washed the windows after a mud bog in comparison , and it will smoke anything from a factory twice over if done right
In SQ comp you would grab trophies galore And it would rival a 20,000 + dollar home stereo easy
https://www.sau.com.au/forums/topic/398464-high-end-audio/#findComment-6331748
Oh well its my brain bump of shite lol someday i should bag that poo instead of dumping in public
Your welcome
now you Decide if you want to go nuts a little at a time or just drop the budget down and get good quality sound still
just about everything is made in china / asia except the above items but you can get some decent sound still If its installed right , if i get some time i might draw up some idea /plans / diagrams etc for people to get ideas and have a visual idea of what is involved , not brand specific either
https://www.sau.com.au/forums/topic/398464-high-end-audio/#findComment-6334557
Best of luck with it , they have been around a while
Made in china but look at it this way , they were made in mexico before So its better quality now
R&D is still in usa if i remember right baltimore maryland
https://www.sau.com.au/forums/topic/398464-high-end-audio/#findComment-6335949
Nobody i know buys polk audio ( vw people do for some reason, same in usa? )
But this should help you
http://www.polkaudio.com.au/html/where_to_buy.html
I would import from usa , save a ton of money just dont get raped on shipping
Hate to say that but a few of the shops listed i would never recommend
Crutchfield sells them in usa mail order and lots of other people but watch it
Warranty void and some usa dealers are dodgy as hell
Or find a listed shop and let them install ?? Your call
Best o luck
https://www.sau.com.au/forums/topic/398464-high-end-audio/#findComment-6343252
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
