Hey guys I was just wondering if anyone here is a spray painter or know any good/cheap painters?
I have just brought a gtr wing in purple and I hope to get a set of side skirts in the next month and I need to get them painted silver?
So any help would be great
https://www.sau.com.au/forums/topic/398563-spay-painter/
A mate at work just had his front bumper done at :
Marko Body Repairs
74 Hoskins Street, Mitchell ACT 2911
(02) 6241 3088
Looks like a good job.
I had some work done at Canberra Automotive Renishers in Belco.
Despite them having to redo some of it, the finished result was good.
https://www.sau.com.au/forums/topic/398563-spay-painter/#findComment-6330323
Goodluck finding a painter though mate, if you want an amazing job done go to fuller brothers, if you want good but cheap marko body works did a quote for my GTR as well, but since it was an insurance job i went for the most expensive =P but i had a good run in with Marko.
Ill tell you i went to almost every painter in canberra looking for one who could be bothered to do the job. its very hard to find someone willing (maybe it was just me)
https://www.sau.com.au/forums/topic/398563-spay-painter/#findComment-6331999
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
