Well I finally had my R33 GTR put on a dyno and slightly tuned. It is stock except for boost restrictor removed and slight timing adjustment.
I bought it when I was living in Perth about a year ago, which is where I had the initial tune done.
Before tune and boost restrictor removed it made 230hp at all four wheels.
After they removed the restrictor it made 288.2hp (214.99kw) at all fours.
Having moved to Canberra, different elevation and temp etc. I thought I would have it re-tuned.
Tonight it made 297.71hp (222kw) at all fours.
Feels slightly different in the way boost comes on but very happy. Not big numbers I know....But one day maybe! ; )
https://www.sau.com.au/forums/topic/399004-just-had-car-dynod/
Plans are:
  • Replace stock turbo's
  • turbo's back exhaust system
  • Cams and cam gears
  • Fcon Pro
Will do turbos and exhaust first and at the same time, then get the other stuff done. Unless I win that $50 million lotto draw! :rolleyes:
Not looking for extreme power. Something super responsive.
  • Not looking for extreme power. Something super responsive.
As someone who has done this (and still doing it), I'd suggest a couple of stages.
Stage 1
Part 1
Turbo's -9, -7 -5 (the smaller the better if you want response) GT'SS good but not worth twice the price of -7's
Exhaust including dumps and high flow cat
I think this should be able to be done without needing a tune, if it needs a tune save the money and get a computer (part 2)
Part 2
Computer, Haltech or Vipec most common and easy to work on with great support in Australia, unsure on the HKS Fcon pro, your choice.
Cam gears
Tune
Expect 260-280kw, fuel being your limiting factor.
Stage 2
Injectors, EG IDC1000
Fuel pump
Fuel regulator
Cams (if you want them)
Tune
Expect 320kw, depends on how hard you want to work the stock engine, this set up is good for much more power with more boost.
Stage 3
Full suspension approx $5000 in new parts + labour
Upgraded brake discs and pads DS2500 or Nismo's highly rated
Stage 4
big brake kit (optional if you find you need it) EG $5000 AP front kit
Stage 5
Rebuild
Stage 5 can happen any time :(
Most here can recomend ESP and Trojan (more good news then bad news anyway). Budget at least 20% more money then quoted for unknown problems that need to be fixed at the same time.
Yeah not likely to get any rust down here, unless its from salt during snow season! LOL
The CV boot cover and CV joint in my XT went during a drive from Sydney to Airlie Beach in Qld when we moved up there. The car started to shake at Mackay so nursed it all they way to Airlie Beach.
I actually think it happended on one of the caine rail crossings as we were fully loaded down and hitting them at about 120-130km's.
    • Well, the trouble with that ^^ is: The configuration shown is absolutely a 1-way, not a 1.5-way. There is no way that a 1.5-way can be said to offer LSD action only on acceleration. If Nismo cannot get that right, then it is impossible to believe their documentation. That ^ is not a 1.5 way setup. That is a 1-way.   And so now I have allowed all doubts to flourish and have gone back to look at the MotoIQ video. I originally made the mistake of believing him when he said "this is a 1.5-way" at the ~6:10 mark. Because what he did was take the gear assembly out of the 2-way opening and just rotate it one place to the left to drop it into the 1-way opening. When he dropped it in there, the cam was "backwards" compared to the correct orientation shown in all other photos of that config. The flat shold have been facing the 1° ramp side of the opening, not the 55° ramp side. And I thought, "gee that's cute", but I was concerned at the time, when he put the other ring back on, that the gap between the rings looked like it was wider then in the 2-way config. And then I said a lot of things in my long post on Tuesday that could only make sense if the guy from MotoIQ was correct about what he'd done. BUT... I have now done my homework. I grabbed a frame of the video with the 2-way config, and then grabbed another with the "1.5-way" config, snipped out the cam and opening of that frame and just pasted it direct on top of the 2-way config. I scaled it so that the triangular opening was almost exactly the same height in both. AND.... the gap between the plates is wider with the cam installed in the triangualr opening backwards. That is.... it cannot go together that way. There would be massive force on the plates all the time, if you could even reassemble it.  So, My statement on the matter? The Nismo diff is actually only a 2-way and 1-way. There is no 1.5-way option in it, regardless of what they say. Here's a photo of a real 1.5-way ramp opening from Cusco (along with the 1 way option). And the full set of 1 through 2 way options from their racing diff, which is not same-same as what we'd typically be using, but...the cams work the same. A little blurry, but it comes from this Cusco doc, which is quite helpful. AND.... Cusco do in fact do what I suggested would be sensible, which is to have rings that do 1 and 1.5, and 1.5 and 2. Separately.
    • Welcome Adam. Car looks great!
    • "With a 1.5-WAY, the LSD is effective only during acceleration."
    • Well it wasn't as easy as I thought.... and it also wasn't in my original manual which I did end up finding. They discuss the process in the Nismo catalogue though and it requires slight machining. Page 145.  NISMO PARTS CATALOGUE 2020
    • I'm an idiot, my intercooler is rated for 1000hp. I had clicked on the wrong product. Knowing the delta P would be nice, but I'm doubtful I'll do it. Now as for an EMAP, that would be great and I'll get around to it eventually but from my findings in my last post, I'm considering a turbo swap now.
