  • Replies 43
hey guys, the problem went away for a few drives now its back, not as bad as before but its still there. cleaned the afm with contact cleaner so pretty sure thats fine. My question now is (assuming it is the ecu), if i take my car to get a tune up (nisstune ecu) will this hopfully rectify the problem. Do tuners usually have spare temp sensors etc on hand if it is damaged, or should i be looking at coming with an arsonal of spares.
In my opinion it's a bad idea to rock up to a tuner with a car that has problems, a tune won't magically fix it.
exactly my thought
guess ill start troublshooting, starting with the temp sensor, makes it hard when its perfect one day and playing up the next.
Ok finally got some spare time to have a look at the NIStune files for warm up timing, i found that 7+ degree's of timing is taken out during warmup up till around 3000rpm then returns to normal, So from now on everycar i do will have this timing put back in.
Kasko when we meet up in June at Eastern Creek i will fix it up for you :)
Sounds great thanks mate!
Thats exactly where it frees up and starts cruising.
Amazing how different it feels with 7 degrees timing
I think it was pulling far far more than 7 degrees, the map I saw had a dip from 20 down to 5 and when I looked in ecu talk it was pulling the maximum timing possible.
It doesn't do it this bad stock though, so I suspect when you start changing injectors/afms etc something else might kick in as well, unsure what.
Hey guys sorry about this, just making sure im following correctly. So its due to my ecu taking timing out when in warm up mode below 3000rpm. But because my car does this sometimes even when hot then this would suggest a temp sensor is possibly damaged telling the ecu the cars cold when really its warmed up, at random times at that?
No wonder mine started doing it as soon as i put the smaller turbo on. You bad boy you.
I am of the opinion there are two maps, cold start and sort of cold start as mine still pulls timing when I drive the car about 5-6 hours ago, eg in the morning it is fine (stone cold) if I leave work early it does it though the warm start map doesn't pull anywhere near as much timing and doesn't really bother me.
The other option is yes your temp sender is stuffed, is your fuel economy ruined? Plug in a consult cable and check the fault codes (not 100% reliable), or simply just check the output when cold and when hot with a multimeter, it should vary.
Edited by Rolls
table is what I meant not map.
There is a cold start and warm start timing map, these are the two that do the retarding. The warm start one is much less aggressive, I'd just duplicate it in the cold start map and then take a few degrees out of the warm start one.
Lots of other handy tables though, coolant temp ignition and fuel tables for when the car gets hot, I put big numbers 110c degrees cell and a bit in the 100 so if it overheats in summer I don't blow it up.
Edited by Rolls
took the car for a drive tonight. noticed the temp guage went up to where it normal goes (did take about 10mins to get there - way longer then it should be) and down then stayed only about 1/3 way up and wouldnt get up to the normal place where it sits. also when it was down the car was boggy and when it was up (briefly) the car ran alot better. obviously after 20mins driving my car had warmed up. my question is does the temp sender also tell the thermostat to open up. or is it my thermostat is not working correctly therefor the sensor telling the ecu if the cars at operation temp yet is getting tricked.
    • Even more fun, leave all the ADAS stuff plugged in, but in different locations, hopefully avoid any codes!   And honestly, all these new cars with their weird electronics. Pull all the electronics out Duncan, and just shove an aftermarket ECU and if needed a trans controller in, along with a PDM. Make it run basic but race car styled!
    • To follow up a question from earlier too since I had the front bar off again (fking!) This is what is between the bumper and the drivers side wheel And this is the navigator side, only one thing but its a biggy! So basically....no putting coolers in the wheel arches without a lot of moving other stuff. Assuming I move to properly race prepping this car I'll take that job on and see how the computers respond to removing a whole bunch of ADAS modules
    • So I prepped the car for another track day on Wednesday (will be interesting to see coolant temps post flushing out and the larger reservoir, with a forecast of 3-14 being 20o cooler than last time I took it out). Couple of things to mention; since I am just driving the car and not taking a support vehicle, I took the rear seats out and just loaded the back up Team Trackday style. Look at all that space! To cover off removing the rear seat....it is weird (note the hybrid is probably different because it wouldn't have folding rear seats) Basically, you remove the lower seat base, very similar to a r series but it is a clip that pulls forward to release the base rather than it being bolted down. Easy Then, you need to remove the side section of the rear seat on each side. There is a 14mm head nut at the bottom of the side piece, the it slides upwards off a hook at the top to release; you also need to unhook the seatbelt from the loop at the top. Then the centre piece is weird. You need to release/fold the seats forward with the tab in the boot on each side From there, there are 2,x12mm headed bolts holding the rear of each seat to the folding bracket, under the trim between the rear seat and the boot (4x christmas tree clips there, they suck). The seat is out but you can see where the bolts attach to the bracket
