  • Replies 57
I'd be interested in the motor... very interested on a few conditions as mine is cactus i think!
ie, can it be tested running?
EDIT: You could keep a heap of stuff too.
I wont need turbo/plenum/intake piping/IC/ECU/Loom or anything.
Just motor/head and thats it.
Actually... series I or II motor?
I would be interested in the exhaust manifold, turbo, dump pipe incl oil and water lines etc.
Plus the associated piping to convert NA to turbo. IC incl oil and water lines
Plus the injectors.
And maybe the ECU.
Also Front rotors and calipers
Cheers
Maxy
Well maybe we could work something out? You in Vic?
I wont need injectors/rail or anything else either. Just the motor and F'all ancilliaries
Not ECU either (i've got a chipped one BTW)
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
