  • Replies 51
Honestly I did try that it didn't make any difference. I tried turning the car off then back on then rereading it then clicking air fuel meter and then changing it and it is still wouldn't write it. And just to clarify do I need to click the update button or write all?
Ok. I will give that a try. I told the guy that has been trying to tune my car and he noticed it as well when he tried to update the air fuel meter it wouldn't take it for him and gave him the same error.
  • 3 weeks later...
Update:
After some ECU pin testing for backup power loss ( Thanks to PaulR33 for the idea) i found that I had none. Swapped the relay with a known working spare and no change. Went to fuse checking for the 1000th time, and I actually found one of the fuses for Engine Control in the engine bay was blown. This was a recent occurence, because I have been checking them periodically. After replacing that one, I continued to re-initialize the FC and re-load my map and settings. Things were looking better b/c the airflow write error didnt show up. I was in the process of cleaning the plugs and decide to check for spark for good measure and noticed no spark. I went back to the fuses for kicks and now the other Eng Cont. fuse was blown. I replaced that one and checked the other one, it was ok still. Spark came back at this point. Finally I was able to actually try and start the car with all of the settings saved in the FC and the car finally started! Now back to point A. Get the car tuned.
THANKS TO ALL FOR YOUR RESPONSES AND INPUT! This is the best source for Skyline owners needs!
And im not sure if anyone has found or linked this site, but I found some rather useful info on here:
http://richr34.wordpress.com/
It is at a slightly higher rpm. I believe it to be due to a fuel issue because I don't know the correct injector lag time so I'm leaving that up to my tuner. My short little drive was my test to make sure there were no other issues that needed to be addressed before I get it tuned. It stayed on the rich side during that sound and i know that my plugs were a little fouled from earlier testing. New ones going in asap for safe measure.
So i have one final bug to work out. On my hand controller i have THRM highlighted. I have read that it should be reading 3.6-3.7 volts. It currently reads .06v. How do i fix this? The trac light is on also. Any ideas. I found a thread on here but the link won't get me to it so I'm not sure how they fixed the problem.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
