  • Replies 51
Honestly I did try that it didn't make any difference. I tried turning the car off then back on then rereading it then clicking air fuel meter and then changing it and it is still wouldn't write it. And just to clarify do I need to click the update button or write all?
Ok. I will give that a try. I told the guy that has been trying to tune my car and he noticed it as well when he tried to update the air fuel meter it wouldn't take it for him and gave him the same error.
  • 3 weeks later...
Update:
After some ECU pin testing for backup power loss ( Thanks to PaulR33 for the idea) i found that I had none. Swapped the relay with a known working spare and no change. Went to fuse checking for the 1000th time, and I actually found one of the fuses for Engine Control in the engine bay was blown. This was a recent occurence, because I have been checking them periodically. After replacing that one, I continued to re-initialize the FC and re-load my map and settings. Things were looking better b/c the airflow write error didnt show up. I was in the process of cleaning the plugs and decide to check for spark for good measure and noticed no spark. I went back to the fuses for kicks and now the other Eng Cont. fuse was blown. I replaced that one and checked the other one, it was ok still. Spark came back at this point. Finally I was able to actually try and start the car with all of the settings saved in the FC and the car finally started! Now back to point A. Get the car tuned.
THANKS TO ALL FOR YOUR RESPONSES AND INPUT! This is the best source for Skyline owners needs!
And im not sure if anyone has found or linked this site, but I found some rather useful info on here:
http://richr34.wordpress.com/
It is at a slightly higher rpm. I believe it to be due to a fuel issue because I don't know the correct injector lag time so I'm leaving that up to my tuner. My short little drive was my test to make sure there were no other issues that needed to be addressed before I get it tuned. It stayed on the rich side during that sound and i know that my plugs were a little fouled from earlier testing. New ones going in asap for safe measure.
So i have one final bug to work out. On my hand controller i have THRM highlighted. I have read that it should be reading 3.6-3.7 volts. It currently reads .06v. How do i fix this? The trac light is on also. Any ideas. I found a thread on here but the link won't get me to it so I'm not sure how they fixed the problem.
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
