Hi guys To cut the story short, I got told the R32 GTR I bought had Nismo turbo's, so had some work done thinking they were steel wheel turbo's.
Had a bit of work done at the shop.. Power FC, boost controller, cam gears, injectors, pump, 302 awkw @ 19psi. 2 weeks later.. Big Bang under boost... white smoke etc... and I found out they ended up being the stock r32 gtr ceramic ones. :\ Not happy as you can imagine...
Just had some brand new 2860 -5's Garrett's fitted up over the last week $, and was wondering does it need to be completely re-mapped again? or just a quick re-map on the dyno. Or Is it safe to even drive or give it some stick? Appreciate your advice. Cheers
Edited by 91BNR32
https://www.sau.com.au/forums/topic/399555-does-new-turbos-re-tune/
Of course, as the amount of air ingested will change drastically across the rev range not to mention there would be less exhaust restriction to dial in more timing.
In saying that, safe to drive provided you don't hit +ve manifold pressure.
.7 bar is the lowest out of the 4 boost settings on the controller that the tuners set up. Sounds like I'll just put it on that and baby it back to them.
Still have standard AFMs so prob make still around the 300ish. But if I get some z32/nismos I've read up these -5s can do 340+ awkw? 19-20psi would be the most I'd run
^^^On a built engine, with all the rest of the car up to scratch yes, if they're bolted onto an otherwise pretty stock GTR (so excluding exhaust, ecu, pod filters) they'll give a crap result compared to the guys with all the right parts and the same turbos :)
Agreed. For some reason everyone latelythinks -5's will give them 380 + kw on a stockish 2.6L. Have a look through the dyno results thread, there are very few that have done this. Most are around 350 and under, and thats with cams etc
On topic though yes you will need a tune
yea I thought about the -9's for that little more response, but selling the car soon, and the workshop already had these on the shelf. Im sure I will still be happy with the -5's as it will be a improvement over the stock ceramics. Still can't believe I ran 20psi through them.. was lucky they only let go and not back through the motor..
Motor was fully rebuilt 3000km ago. Built to N1 spec, N1 pistons, oil pump, etc etc. so by all means no fully forged motor.. Still okay for 20psi though.
As much as i dont want to say this u cant be certain no ceramic dust has gone back through the motor but u may be lucky.
Xcalaba has run big boost on stock ceramic turbo's for a long time. No one is sure how- i think he is using witch magic :P
As much as i dont want to say this u cant be certain no ceramic dust has gone back through the motor but u may be lucky. Xcalaba has run big boost on stock ceramic turbo's for a long time. No one is sure how- i think he is using witch magic :P
I hope im lucky.. thats the last thing I need... :( The car still idled and drove completely fine when not putting it under boost after it let go.
Car Has no Cat on it, and I was giving it boot when it went bang. So im hoping it just blew out the back. (the rear turbo exhaust wheel went.) For piece of mind I will do a compression test to just be sure.
Edited by 91BNR32
    • I might just check it out.. A Q among all those skylines.. lol
    • Time will tell, they're doing all the admin stuff at the moment. I've submitted all the required details, photos, etc.   I was under the impression that DC coupling is the best approach, i.e.: Solar Array -> Battery Invertor -> Battery  Where as AC Coupling is simpler, however less efficient, i.e.: Solar Array -> Solar Invertor -> Battery Invertor -> Battery
    • The price is really great for that kind of capacity. I thought similar setups cost way more. How's your efficiency been with the DC-coupling? I've heard sometimes there can be a bit of a performance loss.
    • Long time no random post about shit. So I went down this deep deep rabbit hole of battery storage for the home, ended up locking in a 41.9kWh Fox ESS EQ4800 with 9 units stacked. Battery uses Lithium Iron Phosphate, similar to what you find in those deep cycle boat/caravan batteries. And yes, why did I go with a cheapie brand and not like Synergy? simply because I don't plan to stay at this house for more than another 3~5 years.  The entire install, DC coupling (removal of existing invertor, connecting the current 6.6kW array direct to the battery invertor), new 8kW invertor is $6K all up (after all the rebates etc.). Going with this lot: https://www.aussiesolarbatteries.com.au/ It did seem a bit too good to be true, however seems like the Whirlpool community has vetted it and when it comes to this kind of stuff, they seem to be all over it: https://forums.whirlpool.net.au/thread/9pxj8482?p=38   I've requested for the battery to be installed outside, next to my meter board and not inside - rather have it combust and ignite outside lol.
    • In Vic it would be a defect regardless of whether or not you cut a hole in the sheetmetal for the return pipe. The rules in Vic are shitful, and are generally interpreted as you can "make 2 mods to the intake system". Putting an FFP and an FMI onto it will almost certainly be seen as some huge number of intake mods. You really need to speak to an engineer before doing this stuff in VIC.
