Hello gents,
I wanted to get some feedback related to the pics.. so just recently completed a full R33 rebuilding.. i've included Tomei cam gears and poncams.. the only problem visually I appear to have is the fact that Timing belt is about 1mm off the cam gears closer to the radiator. Tbelt does not appear to be walking as i've taken it all apart again to check the bottom pulleys and all is in check.. belt is in-line with all the side covers and doest move around, it just that it sits a nudge past the edge.
Anyone else encounter this? Prob is i never took a pic with OEM cam gears to see how it sat and measure the gears for comparison purpose.
All feedback is appreciated!
Tks!
Edited by hybrid_eg
I think the idler is missing the washer that sits behind it. Do u remember fitting this washer?
If u have a good look the idler pulley will be sitting closer to the head than the rest of the pulleys.
I thought the poncams were dialled in and were best suited to the stock position eliminating the need for cam gears? I could be wrong as i am mildly retarded but just thought thats what i had read?
Hey, you know what they say if it doesnt look right then it probably isnt and that doesnt look right.
Pull the front down again and recheck everything. if you have a service manual with a exploded view it will show all the washers and spacers go.
Once it is apart hopefully it will be obvious.
I have seen a few engines with the tomei gears and none have sat like this.
  • 5 weeks later...
As i remember everything was installed correctly reusing the washers.. the belt is not walking its just sitting in that position. Does anyone have a picture with same set up installed to see the position?
Both cams and cam gears?
Not the same setup, but this is my NEO and shows where the belt should sit if fitted correctly -
When the belt was installed, it was even with the cam gears.. however, the motor was run, the belt centered itself in the position where it seems to be off.. (original pictures).
The washers from the FSM are all there.. so i'm not sure what gives..
It indicates that something isnt lined up... The belt will generally straigten itself to the correct position as the crank gear kind of acts as a guide.... Either way, something is not right and i wouldnt be leaving it that way!
When u take the lower timing belt cover off u will notice that the idler or tensioner or both are sitting too close to the block in relation to the rest of the pulleys.
There is a washer that normally sits between the block and the idler
I didnt get a chance to take it all apart but took some more pics to share.. From what I can see on the manual instructions on tensioner there is only a spring in front of it.. od idler, nothing.. So i'm not sure why everyone is advising it could be a washer when its not pictured in the manual? There is a washer in front of the bolt that wil not offset distance between pulley and block.
This is weird..
Edited by hybrid_eg
I've recently installed some tomei cam gears. The timing belt should definitely not be sitting so far forward. I noticed at one stage that the spring on the tensioner can actually fall behind the tensioner pulley which then makes the tensioner pulley not sit square. This can then make the timing belt move forward. Maybe the spring on the tensioner is between the tensioner and block - try checking that maybe...If you just keep cranking it over manually, the belt should stay pretty well centered. Basically something is making the timing belt 'move' forward from its standard position. The question is what...
Good luck. I would not conitnue until I had this resolved and fixed....
I'm taking it apart on Thursday to check spring, and measure everything to see what gives.. also keep in mind originally I had the belt flpped the wrong way ( didnt see the mark on the Tbelt) and really thought that could have been it, when belt was reintalled it was put in the correct position, however when motor starts it moves forward.. and stays in that position.. it doesnt walk like you would see on a stretched belt..
    • HFM BM57 has a "bad" knee point, IIRC. It's not the same thing as the later R chassis MC.
    • The ATTESSA is functionally identical to R34; there were a bunch of JDM models that continued ATTESSA including Fuga/Q70, Skyline/Q50, Cima etc as an option. All with Auto only and I think mostly for snow regions. AFAIK there were no AWD VR30DDTT sold in Australia - it is on my to do list to check regs for racing a LHD car in Targa/ATR/AASA/CAMS events because if I can get the auto to work it would be interesting to run a 4wd car The Ecuteck TCM tuning is the same model as their ECU tuning, they already have it for R35 and Dose's favourite, BMW. You buy "points" to allow your computer to be tuned, buy either a bluetooth (phone app) or bluetooth+USB+Key (phone and PC) dongle, and pay for a tune that will be locked to your tuner ( ). You can also access the tuning software yourself but 1. it is mega expensive and 2. these computers have a billion parameters that intersect, so how could you ever spend enough time on it to get a decent result.
    • Or, is it a case of what it is like owning an R series Skyline? NFI what the previous owner has done or fiddled with... Ha ha ha After reading through this thread, I went on a bit of a research about the Q50/Q60. Now I'm quite intrigued by them! Is the AWD in them more like a WRX where it's always AWD, or is it more like the ATTESSA in the GTRs? By the sound of this TCU tuning, this sounds like a case of someone has made some real software for it, and you just need the right piece of hardware, and then you license that specific vehicle/TCU. Or is this a case of the software will be really expensive so only a few tuners have it, and you still have to pay a license per vehicle?
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
