http://a7.sphotos.ak...0_n.jpgForsale: front mount and most piping off a r31 skyline - $100
For sale : set of Simmons 16x7. One needs new lip - $300.
For sale: pair of 17x7, plus an extra that has started to crack - $ 50
For sale: damaged 18x8, 18x9. Hoping for some coin but most likely take them for free.
For sale: pair of 17x7 - $ 50
FMIC and Piping sold
Hey Guys,
I have a S14 SR20DET engine with 5 Speed Manual Gearbox for sale,
Block had had one rod and piston come out the side of the block but there rest of the engine seems to be fine ( yes that includes the top end ) we are pulling it apart at the moment and selling parts off the engine like water pump and oil pump and CAS, Throttle body manifold, big single turbo (GT3076 no shaft play) gearbox all gears have a nice feel to it ( no crunching ) clutch is not so good probably a throw away, flywheel (may need machining ) front drive shaft, high mount manifold.
Pics will not be posted but you can view all the parts at my workshop, and make a offer from there.
contact via PM, or sms 0404 543 040
Edited by bnpcustoms
Aww that makes me sad I miss NUR! Someone buy the plates and the car to go with it to restore our perve factor :)
That was my plan... I wanted to buy the GTR back from NSW and put the NUR plates back on it. But I don't think its gonna be possible now so that's why I have the NUR plates up for sale.
If anyone is interested in them gimme a pm. cheers :)
  • 3 weeks later...
For sale: $150
Set of Driftworks braides lines for 32 GTR (pretty sure, may fit others)
Front and rear brake lines out of packet, unfitted.
A bag of 6 retainers.
Clutch line still in bag, Note: Input thread into slave cylinder is the same size as a brake line thread.
Clutch line may suit other Nissans as well.
Selling because they sent the wrong kit for my 32 gtst, and im sick of arguing with them over it.(over a week of bullsht)
Pm sent
For sale:
$20 - 5m 0 gauge cable.
$10 - Throttle body rb 20?
$20 - Good fan clutch.
$15 - Good fan.
$15 - Fan shroud R32 .
$10 - 3 inch empty cat (gutted).
$10-$30 - R32 dash vents, sun sensor.
$15 ea - 3 inch stainless flanges.
$20 - Turbosmart bov with RB adaptor.
$5 ea - Various silicon joiners for intercooler piping.
$50 - 3mm alloy checkerplate 1200x1230
$20 - Aircon temp sensor- outside, front. R32. New in box.
$40 - Ford intercooler, 360mm x 260mm bar and plate, 2.5 inch angled outlets.
$80 - RB20 turbo, seems in good cond, with actuator.
$150 - New Driftworks braided hose set for 32GTR, front and rear brakes, clutch, 6 retainers.
Stock R33 GT-R wheels for sale.
Gutter rash on all four wheels from previous owner, but no cracks or buckles etc.
These are still on my car but should be off by next weekend with my new wheels arriving tomorrow.
Looking for $650 ONO.
Cheers.
Cheers.
PM sent
I have a pair of stock R33 GTR turbos off my blue thing sitting in the shed that came off at about 70k when the HKS units went in. No idea what they are worth, but PM me an offer if interested.
Also have a pair of R33 GTR Nismo clear side indicator lens thingies in good nick that can be yours for a measly $30, and a set of R33 GTR Yellowjacket coil packs that have done less than 1000K's work for $200. Think those will also fit some Stageas and S1 R33 GTS-T's from memory, but you would need to check. Again, do the PM thing if keen.
Cheers,
JD
    • No, you're wrong, and you've always been wrong about this. The Nismo has 2 sets of openings. One is a real 2-way, and the other is a 1-way. There is no 1.5-way possible with the ramps that they offer. A real 1.5-way does exist. That Cusco stuff I posted is a prime example. If the forward drive ramps are, say 55°, and the overrun ramps are, say, 30°, then you will get about half as much LSD effect on overrun than you do on drive. It is real, it realy works. OK, you're slightly right. The Nismo has 55° and 45° ramps on the 2-way, so it does offer less LSD effect on overrun. But, I think that just means that they've (probably) sensibly established that you do not want actually equal LSD effect on overrun. You just want "quite a lot, but not quite as much as the drive LSD effect".
    • Just wanted to unearth this and post my baby with the new front ❤️😝 Took her to my wedding rehearsal today. Next up is getting wide skirts (after wedding)
    • Yea, that is what I was getting at in my ramblings too. The nismo one actually is a 1.5 way and a 1 way. They don't do a *2* way because a true *2* way would have equal ramp angles. Or is that a true 1.5 way? Realistically I think a "1.5 way" does not actually exist. A diff can either lock in two directions or one. It also doesn't help that a LOT of people in Australia speak about 1.5 way diffs are referring to their 1 way diff.
    • Well, the trouble with that ^^ is: The configuration shown is absolutely a 1-way, not a 1.5-way. There is no way that a 1.5-way can be said to offer LSD action only on acceleration. If Nismo cannot get that right, then it is impossible to believe their documentation. That ^ is not a 1.5 way setup. That is a 1-way.   And so now I have allowed all doubts to flourish and have gone back to look at the MotoIQ video. I originally made the mistake of believing him when he said "this is a 1.5-way" at the ~6:10 mark. Because what he did was take the gear assembly out of the 2-way opening and just rotate it one place to the left to drop it into the 1-way opening. When he dropped it in there, the cam was "backwards" compared to the correct orientation shown in all other photos of that config. The flat shold have been facing the 1° ramp side of the opening, not the 55° ramp side. And I thought, "gee that's cute", but I was concerned at the time, when he put the other ring back on, that the gap between the rings looked like it was wider then in the 2-way config. And then I said a lot of things in my long post on Tuesday that could only make sense if the guy from MotoIQ was correct about what he'd done. BUT... I have now done my homework. I grabbed a frame of the video with the 2-way config, and then grabbed another with the "1.5-way" config, snipped out the cam and opening of that frame and just pasted it direct on top of the 2-way config. I scaled it so that the triangular opening was almost exactly the same height in both. AND.... the gap between the plates is wider with the cam installed in the triangualr opening backwards. That is.... it cannot go together that way. There would be massive force on the plates all the time, if you could even reassemble it.  So, My statement on the matter? The Nismo diff is actually only a 2-way and 1-way. There is no 1.5-way option in it, regardless of what they say. Here's a photo of a real 1.5-way ramp opening from Cusco (along with the 1 way option). And the full set of 1 through 2 way options from their racing diff, which is not same-same as what we'd typically be using, but...the cams work the same. A little blurry, but it comes from this Cusco doc, which is quite helpful. AND.... Cusco do in fact do what I suggested would be sensible, which is to have rings that do 1 and 1.5, and 1.5 and 2. Separately.
