Selling a brand new Python 574
Alarm can be intergrated with your smart phone for keyless starting, phone disarming/ arming, GPS traking, Do not need this anymore will sell it for a cheap price of $180 ono
Item Condition: Brand New
Product Features:
  • Responder LC3 SST 2-way LCD Pager Car Alarm with1-Mile Range and Remote Start
  • Priority user interface and icon map
  • Priority 5-button user interface
  • Remote can confirm commands with tones, vibration, text and icon display
  • Remote notifies of security intrusions with tones, vibration, text and icon display
  • Powerful lithium-ion rechargeable battery with mini-USB charging
  • Integrated text display
  • Tone, vibe and display notifications and confirmations
  • Car finder
  • Fail-Safe starter kill
  • Revenger soft-chirp six-tone neo siren
  • Onboard Stinger Double-Guard remote-adjustable shock sensor
  • Warn-Away features a low-volume, brief warning signal for potential threats
  • Silent Mode alarming and disarming
  • Keyless entry with optional progressive driver's unlocking and ignition-controlled locking
  • Trunk Release
  • Manual transmission mode
Product Convenience Features:
  • One mile range primary LCD SST remote
  • Slim 5-button SST 1-Way companion remote control
  • Priority 5-button user interface with easy 2-car operation
  • Control Center with integrated status LED and valet switch
  • Virtual Tach RPM sensing
  • D2D serial data interface for Xpresskit D2D serial data interface modules
  • XpressPort dock for Xpresskit docking serial date interface modules
  • Onboard Flex Relays for remote start and light flash
  • Advanced remote start functions: Timer Start, Smart Start, RunTime Reset, and more
  • Active Temp Check displays internal cabin temp while remote start engaged
  • SilentMode2 alerts of intrusions without vehicle siren or light activation
  • Inputs for doors, hood and trunk monitoring
  • Progressive door trigger
  • NPCincluded (patented Nuisance Prevention software)
  • Ports for optional tilt, glass break, cabin and proximity sensors
  • 3 additional auxiliary outputs
  • 1-year Sonic Electronix warranty
Thinking about selling my R32 as a rolling shell (no engine, gearbox or diff). It will however come with another RB20DET, gearbox and diff with the sale. Not very pretty because I've been using it for drifting, but R32's look so cool.
It does have on it:
- Adjustable castor rods
- HSD coilovers but one dampener needs a rebuild (bound feels like it's blown out).
- Has Potenza front struts because of the coilover problem
- DVD player and motorised touch scren (1 DINN)
- Project Mu front brake pads
- Bosch 040 intank pump with relay from battery
- 2.5 months rego
- Hicas lock bar
- GTR rear cradle (suspension knuckles)
It will also come with separate:
- Original RB20DET (I was running a RB25)
- RB20 gearbox
- VLSD
- Flywheel, HD clutch/pressure plate.
After $2500, I think I can wreck it down for the same price. If you're after parts let me know and I'll consider wrecking it down sooner if I have enough interest. I might even put a RB30 into it in the mean time.
EDIT: No pics of it at the moment, any that I do have I don't want to post :P.
Anyone have a cheap 18" 365 35 tyre I can buy as I have a delainated one and I need to replace. Would be super helpful as the other rear is still reasnoble and I dont want to switch to the ugliest 17's in the world.
Cheers,
James
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
