intake manifold (with injectors and fuel rail )
both rear lower control arms
clutch brake pedal plus master cylinders
cas
tail lights
fuel pump
adjustable front tie rod ends
take the lot for $150
s2 r33 front seats $100 for both
3 out of 4 will line up, you just need to extend one of them an inch or so i think.
There is a write up on a few different forums IIRC
Passengers is really good, drivers has a slight split in the seam of the RHS of the drivers bolster but 20 cents worth of blue thread and a needle stolen from your nan should fix it. I shampooed them not long ago. I can take some pictures if you are interested.
PM'd you :)
Brand New Unopened 2" SPECO 533-03 Street Series BOOST GAUGE - $50.00 $40.00 pickup or $50.00 Posted.
Want it Gone.
Buy the flamin mongrel ya dream boats!
For the love of rajab. :worship:
17x8 and 17x9 35p OZ Racing wheels, have 235 and 255 used semi slicks.
$650
1403366_10152005768391387_202506468_o.jp
Water/methanol injection kit with water/methanol mix and methanol.
$300
1403293_10152008410736387_737375936_o.jp
Nissan Micra Super S 1995, has new clutch, nismo engine mounts, ball joints and driveshafts. No rego.
$1000
Bolt on supercharger setup for 1uzfe, needs intercooling or a new pulley made to lower boost from 22psi.
$3000
1093920_10151839688001387_293295834_o.jp
All located in Tuggeranong
0435 626 691
$650
$300
$1000
$3000
0435 626 691
I want the micra, but no kesh :(
661 Carbon fibre full face pushbike helmet, size MEDIUM. Purchased brand new, worn 2 or possibly 3 times, never actually utilised (ie never had a crash while wearing). Minor cosmetic scratches sustained while moving house; in no way affects safety, you can barely see them. Helmet is the same as below picture.
$200, will post at buyer's expense
Mace "swat jacket" body armour, unsure of size (can check). Worn only once, never utilised either. Comes with detachable armadillo-style spine protector. Same as pic below.
$150, will post at buyer's expense
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
