I did for the helmet, and can get the size of the jacket for anyone actually interested in buying it. I'm 173cm tall 78kg, average upper-body measurements, and it fits just as well as when I bought it weighing only 70kg.
Yeah but I want to head down the coast this weekend and my exhaust it leaking and too low to the ground.
Tried to go to the exhaust place today and he said that it's too large for him to work on
Heard that one a few times. She had no say on the matter anyway.
  • Like 1
Roadway is not busy today, got mine done thismorning.
And he wont say its too large, lol.
Too large to work on... thats what she said...... :P
Edited by D.I.Y. Mik
600 CC Siemens Injectors for RB25DET R34 NEO Motor.
Body Design: STANDARD-length, composite plastic
Flow rate: 600 cc/min, 57 lbs/hr at 43.5 psi
Injector type: Saturated
Configuration: Standard Length - 2.5 in., 2.0 in. o-ring to o-ring
Connector type: U.S. CAR (New-style V=EV6 / Oval / LS2)
Fuel Nozzle: Single-hole, tiny droplet
Resistance: 12.5 Ohms, high resistance
Diameter: 16 mm
O-rings: Viton, Top and bottom, 14.5 mm
Part number: 109958
SETS FACTORY-MATCHED TO BETTER-THAN 2%
Sell for $300
0421 669 603
For sale:
Greddy catch can. 1L capacity. - $50
HKS Super blow off valve with pipe (This is the first gen model). Suit Rb26dett. These are non flutter type (Just dumps the air in 1 go) Atmospheric. These are the high load BOV for use with more power -$100 for both with the pipe.
Standard RB26dett Injectors - $250. Also have fuel rail to suit if need be.
Standard R32 GT-R Airbox with new filter. $200
Also have an old boost controller with everything for $50. Can check what it is if anyone is interested. Worked fine before i put my new one in.
Also have Two apexi pod Filters (used) someone can have both for $50.
Can get pics of the other items if people interested.
- Apexi SAFC (Black) - $250 used
- Greddy Profec B Spec 2 boost controller- $300 used
- GCG GT30 0.82 rear housing (internal wastegate) - $350-$400 NEW
- wastegate actuator 12PSI w/bracket - $100 NEW
- 5 bolt dump pipe - mild steel - $150 NEW
- SOLD
- Oil cooler/relocator kit (fits RB) - $180 used - SOLD
- R32 GTR wing - Dark metallic blue - $150 used
- Kinugawa TO4E oil drain - $50 NEW
- SOLD
- HKS SSQV (comes with circlip/2bolt mount to fit RB25DET standad BOV position $100 used
- Stock RB25DET ECU - $120 used
- Stock RB25DET Air Flow Meter - $120 used
- 2x Federal 595SS 245/45ZR18 (lots of tread) - $100 used
- Tein HA Coilovers to suit R32 GTST rear pair(need shocks rebuilt) - $100
- Trust Airinx air filter (should suit stock skyline AFM)- $100
- Nissan R31 Skyline Wagon (Series 3) - will confirm K's (under 200), motor very healthy, very tidy apart from a few small dents, Auto, Cruise Control, Alpine CD Player - $1200 ono
All prices quite negotiable. please give me an offer.
PM, text or call 0431900505.
may forget to check this for a while so please PM, text or call
will post pics eventually, can send pics if requested
Would prefer local sale
located in Woden, ACT
Cheers
Simon
post-27427-0-78494500-1365815252_thumb.j post-27427-0-99454600-1365815254_thumb.j post-27427-0-07171800-1365815264_thumb.j post-27427-0-04689000-1365815266_thumb.j post-27427-0-52514000-1365815273_thumb.j post-27427-0-44306300-1365815275_thumb.jpost-27427-0-50180600-1365815277_thumb.j post-27427-0-61105500-1365815279_thumb.j post-27427-0-52966400-1365815281_thumb.j post-27427-0-48292800-1365815283_thumb.j post-27427-0-70125000-1365815385_thumb.j post-27427-0-55363300-1365815388_thumb.j post-27427-0-47027000-1365815392_thumb.j post-27427-0-22023400-1365815394_thumb.j
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around with a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
    • It ended up being that orientation of the float hub in relation to the clutch disk, when I installed it, I heard a loud click and being stupid, I decided to not take it a part and check it. The hub didn't properly align with the clutch disk and was causing the issue. Definitely an odd one! Dahtone Racing was able to fix me right up, stand up blokes!
    • Right, but I'm saying on the stock ECU measured airmass from the MAF is no higher than stock. So it's accounting for the higher flow rate iso-manifold pressure. You just have to keep turning down the boost until you're within the stock tune's load scale. If you run off the end there's no telling what will happen. This does mean there's zero benefit to the turbos you're running vs stock, if anything it's just a straight downgrade because the transient response is worse, you don't even get the ECU's boost solenoid helping to pull the wastegate closed during initial spool, and peak power is only whatever the factory map can give you before you hit the R&R corner. On a -9 I would bet that you would have to change out the wastegate spring once you have a real ECU and you're tuning it for real. I'm not saying this is a remotely ideal state of affairs, it's just a way to keep it driveable until you can get a proper tune done.
