Whatever Jezz offers, I'll go $20 higher!
Jks :P
That would be fun, stock r34 turbo alright at 12psi?
Haha IHY !
Yeah R34 can run 14PSI (Safe) from what I've been told. 12PSI is a nice middle point.
rofl that R31 wagon is tempting, but it's a bit exxy for something that'll wind up against a tree/boulders LOL
$1200 ONO
Perhaps you'd like to suggest a more tree/boulder smashing appropriate price? heh
Jks :P
Orly? haha
For sale:
Greddy catch can. 1L capacity. - $50 SOLD pending pickup and payment.
HKS Super blow off valve with pipe (This is the first gen model). Suit Rb26dett. These are non flutter type (Just dumps the air in 1 go) Atmospheric. These are the high load BOV for use with more power -$100 for both with the pipe.
Standard RB26dett Injectors - $250. Also have fuel rail to suit if need be.
Standard R32 GT-R Airbox with new filter. $200
Also have an old boost controller with everything for $50. It's an original Profec-b like this one seen below:
Also have Two apexi pod Filters (used) someone can have both for $50.
Also have a set of original Cams in decent condition. Can make an offer if you like.
Can get pics of the other items if people interested.
Edited by Anfanee
Haha IHY !
Just coz the turbo will push 14psi, doesn't mean the ECU will allow it ;)
Disclaimer: I have no idea when R&R kicks in on stock R34 GT-T ECU.
$1200 ONO
Orly? haha
haha sub-$500 (and that's only if I'm going halves with someone lol). Wouldn't wanna defile a half-decent car though.
It's too nice to break, would be sad to see it ruined...
All proceeds go towards getting the toy car running again though!
  • Like 1
Yeah exactly. Would need to be a banged up shitter with barely any rego (and maybe even a slim chance of it being able to get more haha).
Also thinking of selling my 250cc Hyosung. Runs perfectly, has brand new brake pads and front tyre. The fairings are rubbed back to paint, and the seat will need replacing at some point. Only needs rear tyre to pass RWC. looking for $1200. PM me if interested and ill take some photos.
For sale:
Sent you a PM RE: boost controller.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
