Brand new OEM centre vents. Suit R32 (a lighter grey). Most likely GTS-t
Could paint black if you have the black stereo surround for GTR
Yours for the low price of $70 (normally $149)
I need dark grey :/
barmp
For sale:
HKS Super blow off valve with pipe (This is the first gen model). $100 for both with the pipe.
Standard RB26dett Injectors - $200 Price drop
Standard R32 GT-R Airbox with new filter. $150 Price drop
Also have Two apexi pod Filters (used) someone can have both for $50.
Hyosung GT250R $1200 for SAU members Still has rego. Runs perfectly. Rubbed back for painting fairings. Only needs rear tyre to pass rego.
I have lots of space, happy to pick them up instead of them going into a bin.
  • cuong nguyen has pmed me saying hed like the shocks but if he doesnt end up taking them you are welcome to come grab whatever you want.
I also have a pair of 17" rims that are just sitting around doing nothing. Pretty sure they are either 8.5" or 9" wide and suit either front or rear gtst offset. Can get pics and more details if anyone is interested. Actually i think if you look back through one of my for sale threads i was trying to flog them off a while back.
Anyway they are also free now if anyone wants them. Could be good for skids or track wheels...
have R33 parts -boot lid $50 and interior - seats and centre console $20 each, rear wing $30., rear tail lights $50 . fuse boxes, rear drive line and arms.. master cylinder $50 other odd bits.
have pink label afm and apexi pod filter all as one piece $70 can separate.. r33 gtst ecu $150
R33 stock clutch heeps on it $100.. r33 exhaust cat back with cannon from dump was 90db on my car and flowed 320kw no restrictions.. $200ono
pls pm me as i dont check back here often.
BUMP
- Apexi SAFC (Black) - $250 used
- GCG GT30 0.82 rear housing (internal wastegate) - $350-$400 NEW
- HKS SSQV (comes with circlip/2bolt mount to fit RB25DET standad BOV position $100 used
- Stock RB25DET ECU - $120 used
- Stock RB25DET Air Flow Meter - $120 used
- 2x Federal 595SS 245/45ZR18 (lots of tread) - $100 used
- Tein HA Coilovers to suit R32 GTST rear pair(need shocks rebuilt) - $100
- Trust Airinx air filter (should suit stock skyline AFM)- $100
- Greddy Profec B Spec 2 boost controller- $300 used - SOLD
- wastegate actuator 12PSI w/bracket - $100 NEW - SOLD
- 5 bolt dump pipe - mild steel - $150 NEW - SOLD
- Oil cooler/relocator kit (fits RB) - $180 used - SOLD
- R32 GTR wing - Dark metallic blue - $150 used
- Kinugawa TO4E oil drain - $50 NEW
- SOLD
- Nissan R31 Skyline Wagon (Series 3) - $1200 ono - SOLD
All prices quite negotiable. please give me an offer.
PM, text or call 0431900505.
may forget to check this for a while so please PM, text or call
will post pics eventually, can send pics if requested
Would prefer local sale
located in Woden, ACT
Cheers
Simon
post-27427-0-78494500-1365815252_thumb.j post-27427-0-99454600-1365815254_thumb.j post-27427-0-07171800-1365815264_thumb.j post-27427-0-04689000-1365815266_thumb.j post-27427-0-52514000-1365815273_thumb.j post-27427-0-44306300-1365815275_thumb.jpost-27427-0-50180600-1365815277_thumb.j post-27427-0-61105500-1365815279_thumb.j post-27427-0-52966400-1365815281_thumb.j post-27427-0-55363300-1365815388_thumb.j post-27427-0-47027000-1365815392_thumb.j post-27427-0-22023400-1365815394_thumb.j
BUMP
- Kinugawa TO4E oil drain - $50 NEW - SOLD
Cheers
Simon
Noooooo, don't sell my SAFC!
    • I was using the wiring diagram I have So 12.74V is coming into the rear Fuel Pump relay as I measured.  When I turn the key to ON im getting 0.6V to the Fuel Pump plug; which i assume is backfeed voltage and doesnt include the 12V from ignition power.  The rear relay is working and being triggered.  From the diagram I clearly see the rear relay 80 = Rear Relay going into the Body/H loom (R-27) 27 = Fuel Pump plug going into the Body/H loom (T-20) 40 = Short Connector (R-27) I'm reading 12.74V on the blue/black wire which is the power for the Fuel Pump   From this diagram I can see the Ignition relay goes into the front and up to the ignition  2 = Fuel Pump Relay <1M> (R-27) 37 = ING Relay <1M> I started from the pump using this reference Which the way I read it (referencing Nissan wiring color codes) is: Pin Wire Color Function 1 B/P (Black/Pink) Ground 2 L/W (Blue/White)        ECU Trigger 3 SB (Sky Blue) Fuel Pump 5 L/B (Blue/Black) 12V Constant Tested SB to SB on Fuel Pump for continuity - confirmed Tested negative on Fuel Pump to 12V battery and L/B - confirmed 12V Pulled the relay putting 12V between Pin 1 & 2 and testing continuity on Pin 3 & 4 - confirmed relay   So that has me looking at this part of the circuit to understand whats happening here...and im still confused. From best I can tell; the disconnect is back to my previous diagram; between Ignition Relay and Fuel Pump Relay...which yet again; afaik is where the immobiliser should.    Thats what I was trying to explain to GTSboy; im not trying to fix it myself; yet I seem to have to get a Masters in Electrical Engineering (while im busy doing my actual job of DevOps & Cloud Engineering) somehow.  I just wanted more expert opinions; or more so that what I tested is correct and proves it to something around that area; to go back to the alarm tech (for a 3rd time) that he needs to fix it. He keeps telling me its not the alarm. He lives on the complete other side of the city so i understand not wanting to make a trip but as I said before if its the alarm it should be up to him to fix it. But he's adament its not; even though I pointed out the FP was immobilised through the original alarm. To my mind; it seems that the ECU is sending the signal; but the ignition is not getting 12V down the line.
    • Maybe also really stiffly sprung track cars. Get the inside wheel up in a corner and all the fun stops. Also me sometimes (rarely) when I have to stand on the brake to convince the diff to drive the wheel that is still on the ground when I'm trying to diagonally get over severe driveway entrance, etc.
    • I feel like I'm missing something. You had an authorised installer come out and install a new alarm. Post install the car doesn't start, and you aren't getting the installer back to fix what they did wrong?
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
