R32 Nissan Skyline GTR 1989 imported by me in 2004. $13,500 or reasonable offer.
Complied in the ACT.
I dont get the time to drive it, would like to see it go to a good home.
Located in Canberra but will trailer deliver to you for cost of fuel + hire.
Last rego inspection:
- Back left handbrake was not applying full force.
- One of the engine mounts is split, don't know how long it was like it, never had an issue before, I bought a spare, haven't fitted it.
- Clear is coming off.
Needs a tune, throttle bodies need balancing. I cant afford to get it done.
Steel wheel ball bearing turbos built by Croydon Motorsport, all the under plenum pipes were checked and replaced because the last mechanic overtightened the water bleed screw and it sheared, so when I changed the water pump I couldn't bleed it, had to dismantle the entire inlet side to fix it. Found the paper gaskets blown in two places so put in HKS metal gaskets.
Had the injectors serviced, removed the fuel tank and cleaned the lines out, new fuel lines as well. new timing belt went in a while ago.
Cat back exhaust, HKS Pods, everything else is stock.
My Gloss black GTR Bonnet
Condition is immaculate
has the heat/sound deadener and squirters
$600 (or $700 if you wish to barter)
most have seen it on my GTR or in my mancave
however if you want to drop by or need pics
Just ask
Cheers
Richard
Will also be selling off both sets of my Rays Volk GTC's soon
Gold set to suit GTS-t's (Face 2)
18 x 9 +29 ®
18 x 8 +29 (F)
4 x Federals RSR's on rims Good tread road legal
Minor rash will be fixed first
Sit hella flush on my 34 GTT
$2400
Diamond Black to suit GTR's
18 x 9.5 +15
2 x Bridgestone Potenza's RE050's (road legal tread)
Minor rash is being fixed now
Also sit flush with guards
$2400
Both sets come with Rays Nuts
- Volk CF centre caps
- Socket/s
Payment plans on Rims available if your not so flush with cashish
Interested in those Dimond Black GTCs
Hi All,
I have the following stuff to sell all pickup in Canberra / QBN.
Price is make are offer on here or via PM... My R33 is sold so no longer needed, this stuff will either be ebayed or thrown out
Stock Airbox with high performance filter... good condition
http://imgbox.com/sf**kqx1
Reverse switch (that controls the reverse lights) Brand new genuine nissan.
http://imgbox.com/xqypXZoU
Plastic Box for POD
http://imgbox.com/oFvc0G3k
Clutch and Fan. Clutch is stuffed!!
http://imgbox.com/THybj6ju
RB25det Head... great condition
http://imgbox.com/sKfHLg24
http://imgbox.com/0YnUVuNc
R33 s2 stock exhaust... all the way from dump pipe to back.. good condition
http://imgbox.com/l0c2GHWp
R33 S1 ABS pump... OK condition should work fine though never tested (i had a s2)
http://imgbox.com/eAV1Owii
R33 Stock wheels
http://imgbox.com/vM0IGwzw
http://imgbox.com/WbVGV2uA
R33 Emergency tyre
http://imgbox.com/bmxZHrPT
Hi All,
Plastic Box for POD
R33 Stock wheels
R33 Emergency tyre
And this should be an rb25det block for sale above not head!!
DOWN TO $12,000 - must go.
Also has Greddy Oil Filter relocation Kit.
Just flushed radiator, fitted new battery (SuperCharge batteries are crap), just flushed and put in fresh fuel.
Pretty sure I have fixed the handbrake issue.
Needs a tune. I cant afford to get it done.
Cat back exhaust, HKS Pods, everything else is pretty much stock.
No rust.
Edited by xfixiate
1990 R32 GTR RB26DETT - $22,000 ONO - 0422626173
Up for sale is my 1990 Nissan skyline R32 GTR, It is in great condition with 84,000kms and the original japanese service books, it has been used as an occasional weekend car.
Panasport G7 C5C 3 piece wheels with Federal 595 RSR 255/45/17 (1500kms on tyres)
Greddy Type S Coilovers
Cusco rear camber arms
Cusco castor rods
HKS pod filters
Greddy Cam Gears
HKS Power FC with hand controller
New Nissan injector seal kit with new Pintle caps (installed less than 300kms ago)
HKS electronic boost controller
3.5” catback exhaust with 4” oval rear muffler (nice and quiet)
RDA slotted and dimpled rotors with Intima SR brake pads (installed less than 1000kms ago)
Genuine Nissan Tie Rod ends (installed less than 1000kms ago)
Rebuilt Drive shafts with new CV boots (installed less than 1000kms ago)
Steering Rack boots (installed less than 1000kms ago)
Rebuilt Headlight Switch (installed less than 1000kms ago)
Wheel alignment performed by Capital Steering less than 500kms ago
Edited by JimmyS
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
