hi guys i have approx 60- 70lt of E85 from hume united - it is in 3 x 20lt fuel tanks - 10days old is in my car which is in my shed -
selling for $80 as i will not use it till end of the year min -
so bring your car round of bring 3 Jerry cans - not giving my cans away as they are brand new -
pm if interested i am in Theodore
my Nismo 740cc injectors on my RB25 are for sale - - have owened the injectors 2-3 years only install 9months agos and done less then 2000km and only one dyno tune - flowed beautiful easy 315kw -
sell for upgrade - still on car will remove if someone purchases -
$400 ono
pm if interested
Edited by Reese69
Selling a few parts from my R31.
R31 Cusco Camber tops, haven't seen much use as I upgraded to coilovers soon after - $180
Garage 7 R31 to S13 Tie rod adapters, lets you use s13 tie rods + ends on your 31 plus more lock - $80
Borg Warner 3.89 diff gears - $120
R31 Silhouette LSD, rebuilt at some point with commodore cones - $50
Complete R31 Diff with Kaaz 2 Way, 4.11 gears, bearings recently changed, slotted brake rotors - $1000
R33 NA GTS front calipers and rotors, also come with pads - $250
Whiteline front and rear sway bars - $250
Autotecnica steering wheel, 350mm, cracked horn button - $40
  • 3 weeks later...
1990 R32 GTR RB26DETT - $22,000 ONO - 0422626173
Up for sale is my 1990 Nissan skyline R32 GTR, It is in great condition with 84,000kms and the original japanese service books, it has been used as an occasional weekend car.
Panasport G7 C5C 3 piece wheels with Federal 595 RSR 255/45/17 (1500kms on tyres)
Greddy Type S Coilovers
Cusco rear camber arms
Cusco castor rods
HKS pod filters
Greddy Cam Gears
HKS Power FC with hand controller
New Nissan injector seal kit with new Pintle caps (installed less than 300kms ago)
HKS electronic boost controller
3.5” catback exhaust with 4” oval rear muffler (nice and quiet)
RDA slotted and dimpled rotors with Intima SR brake pads (installed less than 1000kms ago)
Genuine Nissan Tie Rod ends (installed less than 1000kms ago)
Rebuilt Drive shafts with new CV boots (installed less than 1000kms ago)
Steering Rack boots (installed less than 1000kms ago)
Rebuilt Headlight Switch (installed less than 1000kms ago)
Wheel alignment performed by Capital Steering less than 500kms ago
No Longer for sale
Did you sell it or change your mind?
Twice I had buyers lined up ready for the sale but I couldn't let it go knowing it was unlikely I would get another one like it. So I am going to be keeping it and doing a few cosmetic changes.
    • Johnny is sad now... Because you didn't get Bosch Motorsport ABS.
    • Hey keep the ideas coming, I'm always keen on projects! But, problem fixed!  I got a cheapie ozito scope from Bunnings and had a good look in and around the bearing and sensor hole. I couldn't see a smoking gun but the bearing looked a bit strange, especially when comparing with a new one. I thought the cover had come off the bearing magnets.  Sorry for pics of a screen, I didn't have an SD card.     Good thing I had the old one to inspect. So, given I'm like a pit crew with wheel bearings and luckily I had a spare bearing because I f**ked up my parts order, I decided to just smash it out. Got the old one out in about an hour. So much easier when the parts haven't had a chance to rust together yet. 😂 And, well, found the problem.    In the second pic at about the 8 o'clock position, you'll see what I think is the tip of the old sensor.  The new sensor has definitely been rubbing but it's all intact, just a little shiny so I'm hoping it's fine.  The car brakes perfectly now and no errors.  I think the job took about 2.5h in the end. 👍🏻 I really appreciate the help in here as usual. Thanks guys.
    • I was only looking because I saw some drops on the ground but it wasn't alot. Recently had it serviced will ask the mech to confirm. Find it strange that it looks standard though, can see in another photo of a random box
    • So...not sure if you know if that has always been there or why you went looking. It could be old damage from a clutch explosion, or even just the gearbox got dropped somewhere along the line. Basically, you should seal it up to stop oil and dust getting into the bellhousing, but it doesn't matter too much and is not structural. I'd suggest something like a glob of JB Weld. BTW what gearbox oil are you running, I would guess the breather has been spewing it everywhere.
    • Hey Duncan thanks for your reply. Sorry mate I know the photos are shit.  Took another photo for reference. Seems the casing does have a hole in it looking on the net, fluid seeping out. Added a photo
