hi guys i have approx 60- 70lt of E85 from hume united - it is in 3 x 20lt fuel tanks - 10days old is in my car which is in my shed -
selling for $80 as i will not use it till end of the year min -
so bring your car round of bring 3 Jerry cans - not giving my cans away as they are brand new -
pm if interested i am in Theodore
my Nismo 740cc injectors on my RB25 are for sale - - have owened the injectors 2-3 years only install 9months agos and done less then 2000km and only one dyno tune - flowed beautiful easy 315kw -
sell for upgrade - still on car will remove if someone purchases -
$400 ono
pm if interested
Edited by Reese69
Selling a few parts from my R31.
R31 Cusco Camber tops, haven't seen much use as I upgraded to coilovers soon after - $180
Garage 7 R31 to S13 Tie rod adapters, lets you use s13 tie rods + ends on your 31 plus more lock - $80
Borg Warner 3.89 diff gears - $120
R31 Silhouette LSD, rebuilt at some point with commodore cones - $50
Complete R31 Diff with Kaaz 2 Way, 4.11 gears, bearings recently changed, slotted brake rotors - $1000
R33 NA GTS front calipers and rotors, also come with pads - $250
Whiteline front and rear sway bars - $250
Autotecnica steering wheel, 350mm, cracked horn button - $40
  • 3 weeks later...
1990 R32 GTR RB26DETT - $22,000 ONO - 0422626173
Up for sale is my 1990 Nissan skyline R32 GTR, It is in great condition with 84,000kms and the original japanese service books, it has been used as an occasional weekend car.
Panasport G7 C5C 3 piece wheels with Federal 595 RSR 255/45/17 (1500kms on tyres)
Greddy Type S Coilovers
Cusco rear camber arms
Cusco castor rods
HKS pod filters
Greddy Cam Gears
HKS Power FC with hand controller
New Nissan injector seal kit with new Pintle caps (installed less than 300kms ago)
HKS electronic boost controller
3.5” catback exhaust with 4” oval rear muffler (nice and quiet)
RDA slotted and dimpled rotors with Intima SR brake pads (installed less than 1000kms ago)
Genuine Nissan Tie Rod ends (installed less than 1000kms ago)
Rebuilt Drive shafts with new CV boots (installed less than 1000kms ago)
Steering Rack boots (installed less than 1000kms ago)
Rebuilt Headlight Switch (installed less than 1000kms ago)
Wheel alignment performed by Capital Steering less than 500kms ago
No Longer for sale
Did you sell it or change your mind?
Twice I had buyers lined up ready for the sale but I couldn't let it go knowing it was unlikely I would get another one like it. So I am going to be keeping it and doing a few cosmetic changes.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
