Hi Everyone,
Not sure if this is the right place to advertise this - let me know if not. Ad is also on 'Whole Cars sale page' with pics etc.
Immaculate R32 GTR for sale
Spent plenty as you do, someone else's chance to enjoy.
333kw (At all Four @ 21 PSI.)
For those that like the detail, let me know and I can provide you with the full list (all internals no expense spared.) Shortened version as per below;
Fully overhauled engine, Balanced and Blue printed (Engine built by Pace Pace Motorsport in Melbourne Tuned by Ed @ Autotech Canberra)
Tomei cams (260-9.15)
Trust high volume sump
Remote oil filter and oil cooler
25/30 parallel HKS Turbos
CES ceramic dump pipes and full high performance exhaust system
Nistune Ecu
HKS Launch Control & torque splitter
Turbo smart eboost
Overhauled gearbox
Excedy triple plate clutch
Koni adjustable suspension
Full customer GTR interior
18 inch Simmons Alta wheels
No money to spend and everything works. Low k's since engine build (has 173,000 on the clock.)
Currently engineered and registered in NSW. All extras and spares supplied with car
Located NSW Far South Coast - Will travel to Canberra for genuine inspection.
$34,900
Reasonable genuine offers considered
post-32547-0-09160100-1420591279_thumb.jpgpost-32547-0-26610600-1420591288_thumb.jpgpost-32547-0-24322700-1420591240_thumb.jpgpost-32547-0-52976600-1420591252_thumb.jpgpost-32547-0-03544100-1420591265_thumb.jpgpost-32547-0-37633700-1420591306_thumb.jpgpost-32547-0-89583200-1420591314_thumb.jpg
Hi Guys,
R32/R33 GTR Apexi Power FC (without Hand controller) $600
2x Z32 AFM (Practically Brand new, done like 2000km) $250 for the pair.
Also still have a set of standard injectors, Standaird Airbox (missing 1 clip) and a set of Apexi pods. PM for more details.
Have an Ogura twin plate clutch here with plenty of meat left on it still. Not using it anymore as I've gone to a quad plate.
Suitable for an R32 GTR.
Don't have the bearing from the centre but they're not that expensive or hard to get. $400, prefer local sale.
Push type
^^ Lots of interest but I still have this and want it gone!
I have some (badly) polished cam covers to suit rb26. Have both cam covers, timing cover, plenum and twin turbo pipe. Dont have a coil pack cover though. Ideally want to see if someone wants a head start instead of polishing theirs. Will swap for painted ones (dont require plenum or twin turbo pipe though). Will get pics when im home in a few weeks if required
god damn why cant it be the passenger side speaker cover!!
Should be able to help you out Nate
Replacing door card in my 32/4 and I'd say the speaker cover will fit
Let you know when it's swapped over
    • The team at OBD2 Australia are pretty good, shoot them an email and ask them. I've dealt with them before for work stuff. I'd be shocked if it didn't work, so long as Consult can activate the ABS. But you might need to use KLine for it which would be the stopper, as I don't think that piece does KLine comms.
    • Yeah and hence my ghetto way of slamming the brakes, get the ABS to cycle, rebleed seems to be a sensible workaround.
    • Hey! Happy to help. Nothing inherently wrong with the adapter, it's more so with Brett Collins himself. He gave me a lot of incorrect information when I was in contact with him and was extremely rude when I challenged him. He stated I could not use any aftermarket twin plate clutches except for his own, not to use the dush shield, bla bla bla and it was all BS.  Collins stated to cut roughly 14mm's off the housing, I took off 15mm to make room for the dust shield. I would confirm with whatever adapter manufacturer you're using.
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
