Hey all I've had these wheels sitting around for ages and have decided to try and get rid of them
Rota grids. Fronts 18x8.5 235/40 with 3-4mm left of tread. Rears 18x9.5 265/35, already at the tread wear indicator. Offsets are around 30ish.
Two different colours - don't ask me why... Previous owner..
$500neg
SOLD
Edited by dontyellpl0x
  • Like 1
thinking about selling up my r33 build, take a look guys
http://www.sau.com.au/forums/topic/454741-eoi-r33-rb25-build-sell-off/#entry7496457
I'm interested in the hicas lockout and the coil overs
http://justjap.com/driveline/genuine-nissan-gearbox-nissan-skyline-ecr33.html
And you want a thousand more for your secondhand box.
Good luck you fkn scab.
Im sick of people selling sht for WAY more than its worth, fk you all.
Edited by D.I.Y. Mik
Anyone have a strut brace suitable for an r33 gtst they want to sell?
Front? Are you on Facebook?
This isn't in Canberra but could be cheap
https://m.facebook.com/groups/2786712445?view=permalink&id=10153238880542446
Edit: post seems to be gone sorry :(
No Worries Dontyelldude. Thanks for the lookout!
Yes front. Trying to make my car less like a snowplough.
Try this. ---> http://www.gumtree.com.au/s-ad/dickson/auto-body-parts/r33-engine-strut-brace/1072388187
    • Pads for R32 GTS-t, R32 GT-R non V-Spec (Sumitomo), R33 GTS-t and R34 GT-t are all interchangeable. R34 GT uses a 2x piston caliper, hence it didn't fit.
    • Checked with amayama and nope, the full S2 manual set is not available anymore. Unsurprising, but still disappointing as the ? on availability gave a glimmer of hope.
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
