I'll have a look around. I fairly certain I have couple stored away.
At a minimum you can test to ensure that's your issue.
That'd be brilliant, have traced the non starting back to that, hope that is the issue, hapy to bug/borrow/rent Cheers! :)
I work in Woden and live in Oxley, friensd in Belco so whatever suits u best Cheers
I'd love something like the wagon, but i need to find one in the couple of hundred dollar mark :(
Wrecking R34 GTT. Been in a crash so front end and drivers side parts might be damaged.
4 inch cat back exhaust
BC Coilovers
Rear Windscreen
Drivers door (glass, regulartor, trim, switches etc) can separate
Passenger door (glass, regulartor, trim, switches etc) can separate
GTT wheels with tyres
Boot lid with wing
Fuel tank
Manual Clutch pedal
Manual Brake pedal
Stock Knuckles
Passenger LCA
Power steering rack
Various interior plastic bits
Seat Belts
Tail lights
Rear Bumper
Power steering reservoir
Rear cradle (would like to sell cradle with arms)
Diff
Axles
Fuel tank (has new cap???)
Tail shaft
ABS unit
Rear brake calipers (can include drums as well)
Brake master cylinder
Passenger quarter panel
Side skirts
Air box
Gearbox (maybe)
Clutch/pressure (plate good, pressure plate is not so good)
Can cut body panels
The engine, loom, computer, front calipers, front seats, dash cluster, fuel pump, side indicators as not available.
The car hit a concrete barrier, it has been bent like a banana. Driver corner was hit hard.
I've sold a couple of things already but feel free to ask.
  • Like 1
Sorry, I've some how skipped visiting this forum.
- Yes, it has a double dinn face panel.
- I will check rear seat and centre console lid and hinge.
If you like, please call me in the afternoon (midday onwards) on O4O3 216 47O.
TRUST/GREDDY oil filter relocation kit to suit RB engines (I presume they all have the same filter fittings?). Comes with hoses, clamps, relocation plate, mounts (well, everything the retail box contained). Never fitted or used.
http://justjap.com/trust-oil-filter-relocation-kit-nissan-skyline-ecr33.html
Apparent RRP of $389....can't recall how much I paid for it, so I'll just say half of that - $185 ono. Happy to post at buyer's expense.
May be interested. Still have this?
Hey guys,
might be looking to sell my R34 GT-T 2001 :(
The car has been in a very minor crash at a set of lights, had it looked over by a couple repair places and they have said that the structural parts of the car are 100% fine but it will need a new bonnet due to it being a bit bent and the headlights have small cracks on top where the plastic brakets holding them on snapped.
The car needs to go over registration at the end of the month, and I may be moving so not sure if it worth me repairing it and the rest just to maybe not really need it in Melbourne.
The car is mechanically great, and also is almost completely stock so would be a great starting point for someone wanting to build something amazing!
I really don't want to sell it, I payed $14,000 for it last year, but I also think it would be best with someone who could apprecaite it more.
I'd much rather sell it on here to someone who I know will take good care of it, and I don't really know how much it would be worth as I've heard offers from $1000 all the way up $7000.
I wanted to see if anyone would be interested in buying it or swapping for something more suited for what I need, like a Subaru Liberty or something.
Thanks guys, if you would like photos or have any advice please feel free to message me!
EDIT: Also in case you were wondering I didn't have comprehensive so my insurance wouldn't cover my car, only reason can't get it repaired as I was the one repsonsible.
Edited by Tudisco
Hey guys,
Hmmmmmm
if only i wasnt kesh strapped....
Hey guys,
PICS Please
    • I was 99% sure the standard one is long enough to get there, you might just have to change the throttle orientation. If not, I remember someone having used an r31 cable instead, but that is probably harder to find than r33 by now...
    • HELP   Hey all, Is there an accelerator cable from another Nissan that can be used on the R33 GTST RB25DET with a Greddy forward facing plenum?  Thanks in advance  Rob
    • Or do we think it was installed to give 1 bar of boost max, all day, everyday?
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
