18" DEEP DISH Manaray Sport VRS Wheels. Offset 35.
Looks great on imports, and wild on Skylines.
Rears run 265's and fronts 245's
Tyres are finished.
Usual gutter rash, and a little clear coming off but nothing that would stop you from buying them.
Pick up only from Queanbeyan.
$300
SemiSlick / Road Tyres. Potenza Adrenalin RE002 245/40/18 X3.
Amazeballs tyres.
2 Really good with heaps of tread, 1 half tread worn.
Only selling as one was slashed, and I just bought a whole new set.
Won't separate, take the 3.
Grab a bargain!
$200
Bellona Rims 19" with 2 almost brand new tyres. 19x8. Offsett 43.
Buy tyres get free rims! 2 tyres 245 / 40 / 19
One rim hit a pothole but is fixable. Was quoted $220 - cheaper if you take the tyre off. Bit of clear coat coming off.
Looks Baddass on a big car.
Usual gutter rash.
$300
Boost Tees:
Regular $25 Posted or pick up Queanbeyan and a free beer.
High Boost Tee from Turbo Tech. From memory it was good for 30psi or there abouts. (Doubt anyone would do that though, but anyhoo)
$35 Posted or pick up in Queanbeyan and a free beer.
Tyres are finished.
$300
SOLD
Amazeballs tyres.
Grab a bargain!
$200
SOLD
Pair of 15x8 40p with 275/60r15 M&H Drag Radials should fit most skylines with rolled guards $750
Sponsor me these and you can both probe my chambers
Guys I'm moving to the UK so getting rid of everything at rock bottom prices.
ORC 559 twin plate clutch. heaps of meat. but needs a new throw out bearing...cause its gone missing.
heaps of meat $400.00
GCG td06-20g bolt on rb20/rb25 turbo. complete with all lines and fittings
used for less than a hour before the head lifted. this is the first one gcg sold and its awesome. matches their high flow but everything is new!
I paid 1425 + freight
its yours for $1100.00
Haltech E11v2 r32/r33 plug in ecu and 3 bar haltech map sensor. This has been in the club forever. was on sins gtr. then owned by tats and shell, then I bought it
$600
Xspurt 1000cc short injectors in an aeroflow rail and turbo smart FPR1200 regulator. This is setup to go under the factory rb25 plenum
its about 6 months old and comes with a loom to fit r33 rb25s. I paid 1300ish
I would like to swap it for some factory injectors and rail plus + $600 cash.
photos and more details to follow.
best to pm me. not really open to offers because its cheap as shit already.
cheers
Andrew
Also selling the beloved car. didn't think id ever sell this thing.
but as above an opportunity to move the uk has come up and cbf dealing with a car sitting here.
so 93 mod R33 gtst
Pretty rough around the edges. and it will be sold as a near stocker unless you want to buy it with all the above parts.
its getting a new head gasket and arp head studs currently. bores look pretty good and can provide pics if needed. I'm not reusing any of the under plenum hoses, Just waiting on an order to arrive from Amayama, all gaskets will be replaced with Genuine Nissan items.
Has BC BR coilovers, r33 GTR seats, a blitz turnflow front mount, fresh "race brakes sydney" rotors and pads front and rear, 80mm momo corsa exhaust and 3"front/dump pipe. Genuine Sparco 17x9" wheels with Federal 595 RS-R tyres with 70ish % tread and some sort of Exedy HD clutch.
ACT rego until Feb
I can't believe I'm doing this....
but
$3k come get it
Best to get me via pm and I'll shoot you my number
but yeah. keen to sell. gotta come up with 10k before July...so buy my junk!
12278802_10153259539731699_3728534172914
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
    • It's TWO steering wheels actually. 😛 one for each hand They are wheels, and they steer!
