  • 3 weeks later...
For Sale:  a set of 17x9.5 +35 & 17x8.5 +35 Work Meister Monoblocks in black.
Have looked for similar wheels to set the price but have been unable to locate an equivalent ad.
Last I saw an ad for them in this size was around $1800.
They're super light and I would love to keep them but need wheels for new car.
Edited by MANG
forgot info
Hey guys,
Have an r33 Nismo catback for sale.
Good 3" quiet exhaust. Would pass rego inspection. Centre muffler is a bit crushed, I bought it like that.
$400ono.
Cheers,
Chris
Hi guys.
Chasing a non neo rb25 head for a rb25/30 build. Prefer something rebuilt.
Just bought a gtt with an rb25/30 in it and just found out there is a crack in the head. Can't be welded. Thought it was just a gasket but unfortunately not.
Send me a text or call if you have something of use.
Thanks in advance.
Dean
0434497483
  • 1 month later...
For sale: for you ACT GTR/RB26 nuts.
1 x Trust intercooler. 600x300x65mm. The usual finning that has been folded due to road use, I had this fitted to my car for 14 years with no issues. Whilst I never removed the original Intercooler to replace it with this one, I'm lead to believe this was a direct for to the standard mounting points.
AP Racing triple plate clutch + flywheel. I never had this in the car, but I'm told by the previous owner it was a) built for big HP uses(obviously...) and b) it was HEAVY if you were considering fitting it to your daily...
I don't have many more details on either, but rest assured they haven't been used much as the car hasn't been on the road for 11 years and the clutch was never fitted in the first place.
$250 ea not negotiable or $400 for both not negotiable.
I thought I'd offer it up to the ACT crew before I list it nationally on SAU.
Cheers, Jayce. d5b968f53119a60857a8318dcd5b21a5.jpg02dfc5cbc22b1b670cf3ee94f2f734a1.jpg
Might be interested in that clutch, as i suspect my nismo one wont hold much longer. Any hotspots or anything?
Sorry from the late reply! Damned notifications not coming through...
It's never been apart since I've had it; it was too heavy for the previous owner so he had an easier one fitted and gave me the AP when I brought the car in 2004. I was keeping it for a higher HP application, but my needs have changed(plus not having the car on the road...for 11 years and counting), hence why it's up for grabs. I can't truthfully say if it has got spots, but it would've needed a heap of abuse from a 1000hp car to do so, and that isn't my car, so I'm confident in its state! Feel free to have a look if you want!
Ill pm you.
  • 1 month later...
Hey all,
Selling Whiteline sway bars to suit r33 gtst. Brand new, never ended up installing them.
BNF24Z 24mm 4 point adjustable front - $250
BNR11XZ 22mm 2 point adjustable rear - $200
KLC108 Front sway bar links - $120
Happy to let it all go for $500.
Can supply photos if requested.
Cheers,
Chris
On ‎3‎/‎01‎/‎2017 at 2:45 PM, Sinista32 said:
Folks - clearing space
Let me know if your interested in these - FOC for ACT folk (must have a 32 though)
FOC = Free of Charge
No takers going in the rubbish. Would be a waste :(
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
