Hey guys
Next door neighbour just crashed his 34 into a gutter.
The whole front left wheel has been pushed back.
I took a few photos and was wondering what you guys would suggest could be broken from the picture.
From what I can tell the only part f**ked is the bottom bar thing (control arm maybe?)
Not to good with the names of the parts
If anyone could help that would be great just so we can start sourcing some parts tonight.
https://www.sau.com.au/forums/topic/399825-crashed-r34-need-help/
Caster arms are pretty strong, especially in tension. Have a close look at the bolt hole through the front end mounting point of that arm. If it is not a snug fit to the bolt (ie, been stretched) then you'll have trouble. Look also for stretching and distortion of the mount itself. Look for evidence of movement of things that shouldn't like the crossmember against the chassis rail. Compare from side to side, etc etc.
No, just that it may be bent enough that just replacing bolt on bits won't fix it. I did a similar thing to mine many years ago. Slight understeer moment into a kerb, pushed the crossmember backwards. We straightened all that out but there has always been something slightly different side to side on the front of my cars since then. It wheel aligns OK, but it's not the same.
You might need to get the car look at by a competent chassis guy if you put it back together and either can't make stuff line up properly, can't get it to wheel align properly, or can't get it to drive properly. If you were in Adelaide I could point you to a guy.
The car might need to be put on a chassis jig and bent back the other way to get things right it it's had a severe tweak.
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
