Microtech LT12s has an AUX output, you need to set up a relay thats triggered from the output, the AUX can be set with RPM on and off. Should see a decent midrange gain from the VCT, it will have to be retuned.
Edited by 51NNA
Nothing wrong with microtech's, i've had 3 car that run them! They never gave me any problems an did everything i needed it to do, no point in buying a ecu with all the bells and whistles if u never use them!
fark it annoys me when ppl post garabage like this about computers... Im sure it will do more then enough for what most ppl neeed.... I never had a problem...
Doesn't mean it is a good idea to run it !
I bet I could set up a carby blow through set up on my rb25 and it would be "good enough" and if it worked I could say "without a problem" as well.
The stock ECU has better tunability than a microtech, it has more features and does an all round better job at every single part of running a car.
You have paid money for a down grade.
You are right I don't ever use my nice cold start, my idle air valve control that automatically adjusts when the AC comes on, I also don't need fuel economy via an O2 sensor.
Actually Rolls, fuel economy is one place where it is so much easier with a Microtech than with Nistune. It's really hard to lean out the cruise section in Nistune. It's a doddle with a Microtech.
You cannot argue against the statement that a Microtech actually does a decent job of running a fairly simple engine like an RB. Sure, you miss out on a few things, but they do work, and are fairly easy to tune (once you're used to their arse backwards electronic carby way of doing things). I'd much rather have a Microtech than pretty much any Haltech that's ever been released.
Yeah I know they work, but the lack a lot of the handy factory features that the factory ECU has. You can lean out cruise on a nistune the same way if you want, just turn off O2 feedback and pull fuel out until you are happy, or if you are lazy just leave the O2 feedback on and it'll be about the same as the factory fuel economy if you don't stuff things up too much.
  • 1 year later...
quote by rolls, "I like to construct strong views on random things, and then argue for absolutely no reason about them." some one needs a hug? anyone in Adelaide can help out?
before you flame me rolls, i agree with you about functionality of the nistune, however they carry an awsome reputation for results built from racing results! They are designed for high reving rotary's with fast and reliable processing time.
  • Like 1
Awesome rep from back in the day when they were a great ECU, it is like getting a magazine from the 90s where windows 95 and a pentium 200 was amazing, doesn't mean it still stands up that well today, sure if all you want to do is run excel from the nineties it probably does it well (eg running a rotary that used to be carby fed), but once again doesn't mean it is great today.
There "fast and reliable processing time" is slower and no less reliable than any new ECU.
Edited by Rolls
They are an absolute bucket of shit. Customer support is pathetic, you can't do a thing with them unless handing over wads of cash and the software sucks balls. We had to send a rb25 one back to get something as simple as a thermo fan output enabled, which is yet something else they charge you for.
The vct can be turned on and off in the aux screen.
what? just highlight the cells you want and press 'O' then drop the value to whatever you want.. it's dead beat simple... I've used Microtech before, it's so damn confusing.
1x table for RPM vs. Timing, then 1x table for Timing trim vs. Load... no sure why they just didn't want to use a 3D map like other people.
Yup. Unless you wanted to keep closed loop. And perhaps you've not tried to do it on a more modern Nissan ECU? VE tables make it hard to know if you're achieving anything at all. You can't switch off feedback on a per cell basis on those anyway.
I'm not defending Microtech by the way. They are unpleasant to tune, as I stated in my original post. But especially back when the only Nissans being played with were RB20s and CA18s, they did a good job, and did return excellent fuel economy - far better than stock.
I do find that the Nistune O2 closed loop is funny, it's quite lazy. I prefer to just set at stoich of the bat for idle/cruise etc. and I turn it off as it comes on song. It tries to stoich coming onto boost which makes the car feel lazy. I've only ever used it on a R33 and S15s nothing newer so perhaps you're right.
Do many people tune nistunes with the O2 feedback off?
you always need to disable O2 feedback whilst tuning, then re-enable it once you're done.. however I just leave it off completely on the idle/cruise cells.
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
