Our new ADM MY12 GTR freshly delivered with less than 50km on the clock and getting ready for roll cage installation next week. This is going to be a minimalist build designed to set the fastest lap times for the lowest spend and show how good these cars really are.
Lots of lessons learned from GTR Mk 1. Mk2 will be better in every way :)
LC5 works a treat.
https://www.sau.com.au/forums/topic/399922-my12-gtr-wr600-club-spec/
  • Replies 167
As far as I know you cannot simply swap discs over to 380s on MY11+ as they didnt just put spacers in there to move the calipers out. It's really annoying as AP are taking forever to release something, DBA likewise and Alcons are expensive.
Martin I may make you an offer, probably depends if it's wet or not at Barbagallo this week...What are you doing brake/caliper wise?
Yes, the new turbos have made a definate difference to the mid range & top end.
It went from 390awkw (E85 & std turbos with midpipe) to mid 400s.
Willalls did the new turbos, dump pipes & full titanium rear exhaust (plus fuel pumps)
in one hit & with the Michelin Super sports I fitted they were arcing up on the rollers
once it got past 420awkw so we dont know exact figure.
Its a massive seat of the pants improvement. I especially love the sound of it now!
It has always been an awesome looking GTR in GT blue, but now it sounds as good
as it looks. Loving the blue titanium exhaust tips as well.
I cant pick any noticable increase in lag, although I do tend to be keeping the revs up
more as I cruise because it just sounds nuts.....
I haven't had a chance to get it up in the hills yet but when I do it will be brilliant.
Martin, when you sort out this Black GTR I will meet you up there!
Munro how's your car going with the willall turbos?
Did you notice a difference in performance from full bolt on e85 to mod'd turbos?
i can say from the passengers seat VERY VERY nice. was in it two before turbo upgrage and the day after, what a huge differance seemed like a totally different car. he can tell you what power it is now (think 800 HP) and from the driver seat.
you beat me too it:) ill put my hand up for a hills blast:)
I'm running basically same mods which is why I'm curious how the turbos added to the driveability as that's my next move.
Have you got the dyno graphs, would love to see the power curve to compare with mine. You kept the stock actuators yeh? What psi did Martin run the new turbos at? ideally I'd want to run 20-22psi right to redline
What about the box, any increase in nvh after opening it up? That's my main concern
Edited by domino_z
Ozstriker we run the Endless full braking system from our old GTR - it was all fresh and outperforms the stock system quite easily. Domino, it looks as though the calipers are cast differently to take the larger rotor...they are all sitting on the bench now!
Syvecs S8 R35 ECU should land tomorrow then some cool things start to happen - boost at launch, rolling boost limiter, programmable launch control. Great development times ahead :)
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
    • The BES920 is like the Toyota Camrys of coffee machines. E61 group head is cool, however the time requirements for home use makes it less desirable. The Toyota Camry coffee machine runs twin boilers and also PID temp control, some say it produces coffees as good as an E61 group head machine.
