So my cars at the tuners getting the new GTX3076R put on with nismo 740cc injectors and exhaust. Its got a rebuilt bottom end with a re-co'd head. Its already got plenty of supporting mods such as Bosch 044 fuel pump, FMIC, Wolf 3D v4. Rang them up today to see how things are coming along and they say the cars detonating in the top end and they're not sure why.
So they asked me what kind of fuel I put in it. I put in a fresh near full tank of Caltex 98 right before I took it to them. They seem to think that may be the problem as Caltex runs a different blend of ethanol, possibly?
So they're going to drain the caltex and try BP ultimate tomorrow.
Can I get some input please, this is kind of worrying me and I'm questioning they're abilities.
https://www.sau.com.au/forums/topic/400306-skyline-detonating-on-dyno/
  • Replies 77
Posted Images
Let them check the fuel 1st then go from there. Did they mention the power it was making ? If around 270-280 at 18lbs it would seem about right. But if all goes according to plan there should be 290rwkws there. If the head was shaved I hope you used a 1.2 0r 1.6mm head gasket.
So you add 0.2-0.6mm for every 0.005" they take off the head?
No they didn't mention the power it was making, I forgot to ask. The wastegate is set to 14 or 16psi. Its a standard headgasket, pretty sure :wacko:
They built the motor in the hands of the previous owner so i assumed they would of known what they were doing. I hope so anyway.
are they familiar with rb and turbos? sounds bad they have no pointers on why it's detonating? o44 & 740s should have plenty of fuel, maybe try somewhere else before they run out of det. time?
Edited by WMDC35
I assume it should be, they're professionals, they should know what they're doing.
They didn't have time to try it today. They put fresh BP in but no time to tune it. Updates tomorrow.
You need to get your car outta that shop ASAP before they knock the bearings out of it (if it hasnt already) or worse... detonating in the top end = big trouble!! Its also the hardest to hear/detect so if they're certain thats whats happening i would be really concerned if i was you... To say they dont know why its detonating is reason enough for any person to question there ability. You need to ask questions like How timing have they put in at the point of det? What are the lambda readings at that point? If those questions arnt answered quickly and confidently then its obvious they dont know what they're doing.
It's sabbadin automotive if people are wondering. I tried to get into JPC but they were being lazy, arrogant regards. Customer service was the worst I've seen.
The tuners pulled the intercooler off and found oil in the bottom, so pretty sure the seals in the old turbo are stuffed. Cooler is getting sent away Monday to get cleaned. Hopefully fixes my issues.
Its more than likely just oil from the cam cover breathers. U may need a catch can to help prevent it filling up the cooler. Most cars will have oil in the cooler.
Is it blowing any blue smoke?
Is the cam timing and base ignition timing correct?
What intake pipe are u running to the turbo?
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
    • Hello everyone, I am happy to join you.
    • Whereabouts are you, that looks exactly like Akira's old car....
