Hey guys,
Ive just finished the painful process of extracting exhaust manifold studs, now apon inspection of my turbo (stock) I have noticed that the swing valve is loose?
Sorry Im not all that clued on with turbos but I am assuming that should be shut pretty tightly?
If it is supposed to be closed tight is there a way to adjust it? Not sure how it all works.
Btw the actuator rod is tight, just the circular swing valve is flappy :/
Cheers
Edit: a bit mor info, the reason for doing the studs was exhaust leak (duh) now, one of the symptoms I was experiencing was a flucuation in boost. Almost like a flicker as it was climing. Now I just assumed that was part of the leaking manifold but now... Could this be caused by this?
Edited by GoHard
https://www.sau.com.au/forums/topic/401007-swing-valve-resting-position/
A picture? I was trying to think how I could take a picture of movement...
I guess this might explain it? Should I be able to slide a piece of paper behind it when closed?
Its loose enough to spin freely with my finger. I hope this helps?
there should be some adjustment on the actuation rod that it's connected to it. adjust the rod so that flap is hard up against the seat. it'd be worth cleaning all the carbon off around the seat before adjustment.
cheers
justin
to me it sounds like there is more wrong with it than just the need for adjustment.
I dont think he should be able to freely move the wastegate with his fingers... or is it just the valve/disc that covers the hole that has some freeplay but the overall mechanism is still stiff and cannot be moved by hand?
Yeah mate the whole assembly is stiff as. Its just that circular disk that sits a bit loose.
See in the pic, i can grab onto the shaft (dead centre of disc) and it feels like very minute shaft play. I can spin it from there.
put some washers between the turbo and the bracket the actuator is on... :whistling:
What I really need is a washer on the swing valve to shim it, but there is no way of taking it apart to get a washer in there. Circlip maybe but thats worth even more :whistling:'s
This, should solve your problem nicely. Put enough washers on there to hold it shut and then an extra 2-3mm, should raise your boost a touch.
Justin, johnathon... Thank you. Thank you so much. A washer under the bracket of both bolts brings it closed perfectly!
Is this safe? There isn't much surface area for the bracket to sit on in the first place so I dont see why not. This has been done before?
Edited by GoHard
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
