Yea its definitely still a problem, sometimes the wheel is perfectly still, yet the car feels like a puck on an air-board and just gliding along with my not having any say. Last night going along at only 70kmh the car definitely wanted to go right, I had to seriously turn left and then back to center to get it right :/
OK, so .... what steering wheel do you have on it? More importantly, is it HICAS compatible?
Have you tried to start a HICAS diagnostic? (google it).
Do you know anyone (mechanic) with a proper scan tool that can report on all the computers in the car? My mechanic has one that reports the computers in the car as being Engine, Trans and Steering (trans because R34 auto ECU has trans module in it - even though I'm using it manual) and my HICAS computer is still present but only partially connected (and completely disabled mechanically). That scan tool reports available fault codes for those computers. Worth a look. You can't always start a HICAS diagnostic to find out if your steering sensor isn't working (for example) because you need the steering sensor (and others) to be working in order to get a diagnostic running!! So scan tools can be a lifesaver.
cheers
Glad I found this topic because my car is becoming increasingly deadly on the road.
Going to be looking at delete or lock as soon as I get some cash.
Would you suggest a delete rather then just the lock bar?
or can a lock bar still bring it stable.
I jacked my car up and you can actually move my wheel because my hicas is so loose..
Don't know on R33s. I put a whole non-HICAS rear subframe from a Cefiro into my R32 and pulled out all the HICAS stuff completely (of which there is a lot more in an R32, being hydraulic).
It's also closer to being legal, as HICAS lock bars are considered a modification to the steering system, which is generally a no-no and an engineering exercise at best.
If I were not to have done the whole subframe, I definitely would have bought one of the more serious delete thingos that replaces the HICAS tie rods with arms with bushes on the end.
Standard GTR wheel from what I can tell. It is possible some sensor is broken or stuck, as for diagnostics I don't think they checked that thoroughly as the loose camber nut was found. But yea I might ask them to do that, I'm sure they have the tools.
These symptoms (or at least the one posted above this post) are usually caused by the steering angle sensor....and more particularly by not having a boss that drives the steering angle sensor.
I thought the same thing but the original steering wheel and boss were in place, I don't believe they had been tampered with, it was intermittent and there was no way to guess when it would happen, either way, all gone, all good.
OP, if you can, just get the system removed and a lock bar installed asap, at least the car will be safe to drive, I know how dangerous it feels, good luck!
Edited by ima_slap_joO
    • If you mean the alarm immobiliser; theyre internal to the alarm itself which makes that difficult; I couldnt even see where he put it; its not in the same place as last time; but with all black wiring it might be very challenging to trace  I had someone turn the key for me as I know it only primes for a couple of seconds As my post above; I am getting no voltage to the pump at all; but I am testing continuity of the power line (SB) from the pump plug to the relay fine. As well as the negative from the pump plug to a 12V constant.    Yeah; he blammed the no start on a bad battery; said I needed to get a new battery and it'll start. Turns out the battery drained because the tail lights had been on for half the day during the install (the rubber cushion on the brake switch gave out while he was testing it as I have a picture of the car from that morning with the tail lights off..i've replaced that). The battery was turning over the engine just fine for a long time; but got low since lights were draining it so it was too low to test a start after he finished. I bought a new one on his advice...$250 wasted. My original battery charged up just fine and is healthy.    It was running perfectly fine when I messed up the old alarm (programmed out the remotes). He couldnt start it after removing the old alarm; my assumption is that when he unhooked it; he didnt bridge the circuit back when trying to start it. Its always been perfectly fine. The ECU swap and pump were 2 years ago. It's never missed a beat in that time.
    • This is a big issue for me without the diff. I just have zero drive from the passenger side when drivers side has no traction. Bec's parents place has a crazy steep driveway with odd camber and I have never been able to get up. My bro-in-law's 130i with an (unknown brand) LSD gets up fine as does their dad's Hiace. My car stays at the bottom. We have other odd camber roads around here as we're elevated a bit and if it's raining I can get totally stuck around some hairpins.
    • Yeah, I am super excited for this.
    • Was the car running before he touched the car?
