I'd go a deatschwerks fuel pump over a walbro... any day.
Don't use efi hose for e85- you need something teflon lined/rated for alcohol.
For the extra money, I still choose ID injectors over the standard bosch items.
J.
He doesnt need teflon or braided hose the efi hose is fine many ppl are running it without problem. Ive got the stock hoses for last 2 yeArs e85 no problem. Its only worth going teflon if your got a hatch boot and smell is an issue or he has extra coin but it is not a necessity.
J.
I've seen the deatschwerks pumps, but why go that over a walbro?
And I've been told by a few people I need new lines, and then by a few I don't... Hmmmm
Yeah at the moment I'm leaning towards just going id1000's
Definitely go with the Bosch 1000's.
The Deatschwerks is well worth the extra $60. Make sure its hard wired with decent cable as they draw 15-20 amps.
Your lines will be fine for years, if they ever go hard and brittle its time to swap them or upgrade to Teflon.
Im going that walbro 400lph E85 pump. The current walbro 255lph I have has been faultless for the 7 yrs it's been in, even ran it with E85 for nearly a year with no problems. I just need more fuel now to keep it safe.
the 400lph cannot tolerate E85.. there are some components in the pump that will wear with e85.. hence why they brought out the 416lph.. im trying to find somewhere local that may have it. perhaps Aznu?
Well I've only seen it listed as 400+lph, so splitting hairs. The part number you/I want ends in 267 for the E85 approved version. Cheapest I've found so far is eBay US for about $260 delivered but I haven't finished searching yet.
Did you see the result on NS.com. A guy just made 295rwkw on 18.5psi with the tdo6sl2-20g 8cm on E85.
Edited by slippylotion
http://www.full-race.com/store/fuel-systems/fuel-pumps/walbro-416-lph-in-tank-e85-fuel-pump.html
im waiting for a response from these guys, and will probably get it from them if Aznew(authorised walbro dealer) cant get it in
from the 22 nov 2011
Hi Gulrez,
Thank you for your interest in our new 400lph high performance pump. Unfortunately, it is not rated for use in E85. It’s not to say that it won’t work, but we have not validated it in E85 and there are components inside the pump that are not properly protected against the harsh conditions that E85 causes. We haven’t heard of any issues with the pump, but I simply cannot recommend the use of it in your application at this time.
On a side note, we do have an E85 version that we are hoping to launch in the first quarter of next year that should flow beyond 400lph. We’ll have marketing data and flow specifications out to the websites and blogs 3-4 months from now. More to follow soon on this.
Best of luck and let me know if you have any additional questions!
Regards,
Kelly Christians
Account Manager - Aftermarket
thats from Walbro itself. there would have been no reason for them to bring out a 416lph pump for e85 if the 400lph would work just aswell..
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
    • If they can dyno them, get them dyno'd, make sure they're not leaking, and if they look okay on the dyno and are performing relatively well, put them in the car.   If they're leaking oil etc, and you feel so inclined, open them up yourself and see what you can do to fix it. The main thing you're trying to do is replace the parts that perish, like seals. You're not attempting to change the valving. You might even be able to find somewhere that has the Tein parts/rebuild kit if you dig hard.
    • Can you also make sure the invoices on the box (And none exist in the boxes) are below our import duty limits... I jest, there's nothing I need to actually purchase and order in. (Unless you can find me a rear diff carrier, brand new, for stupidly cheap, that is for a Toyota Landcruiser, HZJ105R GXL, 2000 year model...)
