Nismo solid shifter
nismo steel braided clutch hose
nismo Gt titanium gearknob
nismo panel filter
nismo front/side indicator's.. hate the look of the imitations
post-69990-0-53012400-1339481559_thumb.jpg post-69990-0-32370700-1339482345_thumb.jpg
only problem is how freaking cold the gearknob gets in winter :P had a nismo cluster too but dumbass auto elec dmgd it :/
yes that front badge is cheapo ebay replica. Does Nismo make front badges?
only negative thing i can say about nismo is the $1200 for rear tail-lights.. c'mon is it just me?
haha nope not just you, thats why I made my own copies..
sorry to hijack :P
nismo parts in my car..
Nismo Rad Cap
Nismo clutch and brake lines (replaed by customs when going bigger rotor)
Nismo gearknob
Nismo GTR front bar
former nismo items,
nismo cluster
oil filler cap
suspension arms
seen a thread on how to make those, looked all nice until it got to the part where he had to make some sort of silicon base or something, then i'm like damnit, don't know how to do that :/
This ?
genuine? where can i get?
my old GTT :wub:
just cosmetic stuff
genuine nismo rear bar, none of that Altia crap they flog off as 'nismo'
:whistling: lol if it wasn't fiberglass i would've gone for it. not a fan of fiberglass at all though, but this is nismo so i guess there's an exception.. looks nice :thumbsup:
Just remembered I had a Nismo leather shift knob on one of my previous 34's.
Was a lot friendlier than my old titanium Nismo knob, after the car had been out in the sun for a while. Also didnt show the fingerprints.
Edited by iwanta34gtr
no way this wasn't fibreglass, or were you referring to altia bars? genuine nismo are made from the same plastic as stock bumpers, came with the car when I bought it :cheers:
It was definitely fiberglass. I've had two of these and still have one that I can't use on my car (wide guards).
So if anyone wants genuine nismo GT/T rear bar, its in the for sale section :)
Small knob.
This is my one too :) good feeling ontop of my c's short.
wow ok never knew that hehe, like I said mine came with my car when I bought it as a fresh import, I was reading somewhere ages ago that these were plastic.
The altia ones are plastic.
All good :) I always hoped factory nismo gear was plastic for durability, but I guess not, some of their kits i've seen (350z and some other pieces) were also fiberglass. But then they also do a lot of their gear in plastic as well.
yeh altia is plastic, got it on mine. and as far as i know and with some confirmation with EZY34 the nismo 1's are definately fibreglass, but like i said, it's nismo so it's not exactly cheapo fiberglass that cracks easy and leaves a really shit finish when painted.
i think the gtr z-tune front bar is in some way fiberglass too (CRFP: caron fibre reinforced polymer)? some say the "polymer" refers to it being glass fibers.. is that wrong?
Understand it is genuine but wouldn't mind confirmation from some one on here.
Advertised as
Nissan Nismo Emblem Badge Nameplate Decal Rare JDM Tuning
  • Approx. (Width) 4.33" inches x (Height) .55" inches. Quick and easy installation!
  • Not a cheap Vinyl or Decal Emblem. Made with Special Aluminum Emblem and Embossed to create a 3 Dimensional surface.
  • Aircraft quality Aluminum. 100% Brand New
  • Hard Anodized in Color for a Long Lasting Finish. High Quality Emblem
  • Comes with 3M self-adhesive backing. Ready to stick on ANY flat surface
$9 ea ???
definately fake. + i would need something that screws on, it's gona sit on mesh. i've seen 1 thats exactly the same as that, probably from the same guy which screws on but yeh deinfately fake. wash your car enough and the red will start to discolour. they all say high quality but even the 1 i have on know is peeling abit..
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
