Very nice and clean, seen it in person too :P more pics pls :)
Half a inch more. I reckon it'd be close.
Of course they are lighter lol, hey bueller we need a thread with more pics of your sweet ride mate. Don't leave us hanging :)
You'd hope they're lighter as they cost about 150000 yen odd new per wheel back when they were produced from memory, double or close to double the cost of the lmgt-4. Not sure what the gt500s cost though.
More pics here or in another thread?
A few -
post-135234-0-09299700-1412675876_thumb.jpgpost-135234-0-49905300-1412675917_thumb.jpgpost-135234-0-09267800-1412675902_thumb.jpg
  • Like 1
Well,,, just read through the whole thread,,,very impressive purchases boys and girls. We are all keeping them in a job.
I was asked by Zebra once why I had a Nismo sticker (chinese copy) on my windsreen when possibly I didn't actually have any nismo gear on the race car. Well there's not that much to buy for a poor old R33 GTS-T but I am doing my best.
Nismo Speedo
Nismo Key
Nismo GTR Fuel Pressure Regulator
Nismo Front Lower Control Arms (Oh wait I bent one racing)
Nismo Rear Upper and Lower Control Arms
Nismo clutch and brake mounting Brackets (not really but nismo cheated by just welding more points)
Nismo Thermostat
Nismo 555 Injectors
Melinda was a bit taken by all the cool stuff Lander Toyota had bought into skippy land many many years ago and bought these 2 items,,,. We still have the receipts somewhere,,,pity we didn't keep the packaging..
Cheers
Neil.
A few -
Close ups would be good including stickers. :)
When and where did u pick them up from Terry? Nice :)
'Twas I Marko who gave you a heads up on this set being on that BCNR33 F/S remember? I said you might ask Kamikaze... if he might separate the wheels from his car that's on offer. Then I noticed you'd ordered new ones so I stepped in afterwards.
Ahhh yes tbh I didn't instigate that path as I couldn't go past the wheels i got being full monoblock forged and less than 8kg superlight :) I'm happy
Besides that, white wheels on silver meh whereas on your white gtr would be nice...are they 18x9.5 Terry?
    • Old Son, did you re-use the Holden ABS in the new shell or try a different module?
    • Yeah, nah. I had the actuator rod off it today. The arm will not move at all. Neither out, nor in. Yeah, you'd think so, but I've been thinking about that. Even when the actuator rod fell all the way off at the beginning of this saga, it would build more boost and faster in lower gears than it would in higher gears, and you'd think that that was the opposite of what should happen. But I strongly suspect that there is a thing with the gearing getting the revs to rise faster, that there must be some transient effect with the gas flow rate rising quickly, that you don't get with the more steady state case of the higher gears. Keep in mind - the gate is not shut in either of my weirdnesses. So things are not "normal". We normally think about a turbo spooling up (below the wastegate target) with the gate shut. I have all sorts of mental models running now where the gate is a little bit open, and having it stuck open allowing gas out while it should be going through the turbine has all sorts of weird effects (in these mental models). I'm thinking in the higher gears, the ex mani pressure builds to the point where enough gases spill out the wastegate to just prevent the pressure rising much more at all, or just creeping up, all the whole the revs are increasing and getting closer to the point where a gear shift becomes necessary.
    • Is it possibly wastegate actuator itself is sticking, or even the rod to flapper? Otherwise I reckon things are getting a bit rusty/worn   Also odd it won't boost in 3rd to 5th, but will in 1st, I'd expect the other way around with it slightly open as there's more time on your way to redline for it to spin up
    • Does anyone know ow what these two plugs are for and if they should be unplugged? Just put the dash back together and can't remember if these were plugged in before or unplugged! (Blue and white plugs) 🤦🏽‍♂️
    • Did some FASTing ...got the impression that the actual part# was a moot point ; seems all of these hardlines for coolant are discontinued/NLA... like, I take it you're after the hardline that bolts onto to the manifold...that's NLA according to amayama & nengun .... ...just to clear up some confusion, they typically mounted the AAC valve to the intake manifold somewhere near a coolant passage, so the body of the valve heats up & holds it open when engine's up to temp - no coolant flows through the valve, it's a mechanical, thermal connection.
