NISMO Super Coppermix Twin Plate - Comp Spec for my BNR34. Super excited!!
Super broke.. :(
Car has more NISMO goodies that I'll mention when I get it back..
Had one in now for a few months and love it :wub: after using a Quad for a DD it is a dream :)
  • Like 1
  • 3 weeks later...
The Group A that was tweaked here by Gibson Motorsport was better than the one in Japan.
The Winfield Chassis #5 sold last year for over $900,000.
The GIO Chassis #4 was sold more recently for an unknown figure.
Both cars were sold with extras including magnesium wheels, trailer, computers, mapping data etc
  • Like 1
I don't know for sure, but I suspect that it was a customer car program for japan. So you fronted up with your $400,000 or whatever the cost, they built a car for you to race in group A under your racing team. Much like you had rouse, eggenberger, and others in the RS500s. So no, there isn't a magical version out there, they are the race cars tucked in the museums in japan. :)
There are 4 remaining australian GTR group a cars. One was destroyed by skaife at Adelaide. 3 are race ready, the remaining one getting put on show in Victorian historic racing events.
pretty sure there are 5,000 homologated group A cars. Then there is 560 "nismo" cars which are group A evolution. The red car pictured is an actual group A race car lol. It was an add for nissan at the time. They had to sell 5,000 models to be in group A. But group A rules at the time said you could use special parts if you made at least 500 to be sold to the public. So that is the reason the Nismo models were made with different aero etc. So they could use it in actual group A series.
LM GT 4's are back baby!
Special engraved logo
http://www.nismo.co.jp/omori_factory/fl_parts/#gt4
Limited to 100 pieces (sets im guessing) get ur wallets ready to RIP! Actually they are a great price at the current exchange rate.
Now we just need the 19 inch version to make a comeback as well. Shame they arent in all colours since im not a big fan of the black but hey its still great to see the love from nismo
Edited by Gts30t
  • Like 1
Surely the yanks will be onto these too with the 32's starting to flow in. If you want a set id be getting in quick, although id say if the first 100 go quick the will surely do another run.
Looks like the got sick of the constant inquireys for more Lm gt4s and finally did a run for us nismo lovers :)
it says that "- First production number will be 100 pieces. After the first number sold out, according to inquiries from customers, there also be additional production"
so they may do another run
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
