Yeah cheers and sorry for jumping in on your discussion but I love the look of that pipe.
A few people on SAU have them (gts25, therealsandybang) but not sure it is a Weldina. I asked gts25 but he didn't think so:
http://www.sau.com.au/forums/index.php?/topic/119761-R32-Pix-Only#entry7545869
its just a nismo, not a weldina. I believe the weldina exhaust will have a weldina tag on them somewhere. I think the muffler tip will say "NE1 weldina". Its a dual 60mm that collects into a 80m. The nismo carbon pictured is a cool item for the nismo freak if you want a non aggressive stainless steel exhaust. Me personally, always been a titanium kind of guy.
  • 3 weeks later...
Im pretty sure you can still buy those strut bars new....for a lot cheaper. At least I know you can for r32. Unless they don't offer that old nismo style plate. I know you have a omori factory or nismo option.
Finally picked up the last piece of old school nismo knick knacks.
Finish off my set of period correctness. I almost feel bad opening these lol. I will use everything but the fashion lighter. To many of those opened already.
Edited by JTCC
  • Like 1
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
