Now they're thinking...
I can get a pair off easily enough > but who do I know that can drill a hole to make an earring?
And that fellahs...
is what happens when your lovely Nismo items are so small and defenceless!
Ummm white spoke stickers? Again Chris, I'd PM elrodeo666 and Marcus will do his best - quickly!
...or eBay. But some stickers can be a fraction too big > need to be the right size if you can.
  • Like 1
If you mean the Nismo wording on the LMGT4, I wouldnt bother with genuine stuff personally.
The last time I enquire about that, you'd need to get them from Rays and they're around 25 or 30 EACH + you need to provide prove of owning a set of LMGT4 (maybe invoice, photos?) before they will sell them to you. This was 2years ago though.
I end up getting the decals from Ebay. All you need to do is measure up the existing one you have and send the dimension to the seller that makes a Nismo decal. Less than 10bucks posted.
Thanks heaps for that!
Do you also know if Nismo sell the white stickers for the Balck LMGT4s?
I gotta say - don't bother getting the nismo wheel valve caps. I had mine on about a week before they were stolen.
I'd only thrown them on after I'd chucked them in on order from RHD with other stuff because they were so cheap - and thought they might set off the LMGT4 and nismo wheel nuts. Ah well.
I recently ordered 4 of these through Streeter, and there was none of this hassle. they cost around 20$ each.....fml but having said that i think i'll get Ebay ones next time!
i have a set..and i'm contemplating whether to put them on or not =(
mm cant help you much there, im pretty sure with the Rs they mount from the passenger side vent on the front bar under the indicator light, but you need the nismo front bar for the outlet just infront of the wheel behind where the cooler sits to actually allow air to flow through... if it doesnt work out on your i would be interested init... but im broke atm anyways haha
haha yeah i've looked up the pics on a GTR and it's slightly different as they seem to have a mounting bracket/bar, i swear this item was advertised for a GTT when i bought it (from Japan)! quite confused. Oh well, will have a look one weekend/when i install FMIC.
  • 4 months later...
available for all models. expensive though for what they are - a cover
Edit: (I painted mine black a while ago and it looks 10x better than the OEM grey)
Now this has come out I'll give it thought.
Edited by Sinista32
Nismo power brace, to suit my 180sx. Nismo take the old stock units, box the sections and add a bar between the arms.idea is to stiffen the front up to prevent flex and make the susp work harder. Finish isn't crash hot, but since it's a under car bit, I'm not fussy. In fact I'm not fussy anyway lol! Basically acts as a strut brace for the lower suspension.
So are they pre-fabricated or do you have to send in your old units? Pretty cool piece either way.
You just buy them, no exchange needed. Guess they go round stealing them off old wrecks and old Oem stock!
Can't work out why one side of the bar is braced extra, but guess they know.
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
