Ok, so after 16 years, 192,912 kms and it's fair share of abuse, MADGTS has finally spat the standard turbo. Not just the exhaust wheel (fantastic diving catch by the Cat) but it also shreaded the impeller. I may have contributed slightly by winding in a tad too much boost - 8psi to about 15psi on the std CPU - but that's all history now. What I do have is a few questions.
When the turbo went bang the car died. It did the normal puff of smoke out the exhaust but basically died straight away. After doing a quick plumbing check under the bonnet for any hoses or connectors that may have come loose (it did sound like a hose had let go) and under the car for any fluid loss, I cranked it over intending to limp it home. The car would not hold idle, in fact the only way to keep it running was to rapidly pump the accelerator but even then the revs would only just make 1500rpm - not enough power to move the car. So I rolled it into the gutter and walked back home (luckily only 300m) to ask the wife for a tow. Once home I gave everything the once over again but could not find a reason why the car would not idle. The turbo has now been removed but I fear that something else may have been damaged as I expected the car to still run minus boost.
What do you think? Could I have done more damage than just the turbo?
Also the turbo will need a steel wheel rebuild/highflow. Is there anyone able to do this in Sydney (Seven Hills/Blacktown/Castle Hill area prefered)? Or should I just send it to Hypergear in VIC as they seem to have the best price and get very good reviews?
Z
https://www.sau.com.au/forums/topic/401738-madgts-go-boom/
:/ no good.... Probably pull the cooler piping off etc and check for metal pieces or shavings before starting it again? Just to be safe...... Pics of the turbo? (Not that it helps, i just want to see what it looks like :D)
https://www.sau.com.au/forums/topic/401738-madgts-go-boom/#findComment-6383492
Will pull the FMIC before going much further and empty anything that may have been blown through. Already checked the piping and connectors for the rest of the inlet. No pictures of the turbo but I have a shot somewhere of the crap I emptied out of the cat. The AFM appears to be ok but I will give it a clean when I have everything ready to be bolted back on. Unfortunately I don't think I can run a compression test until the turbo is back as any cranking of the engine is likely to spew oil (and whatever is left of the coolant) everywhere.
So is there a reputable turbo place based in Sydney that can highflow my turbo? I'd rather save the transport cost of sending it to Victoria.
Z
https://www.sau.com.au/forums/topic/401738-madgts-go-boom/#findComment-6383577
The high flow that was on my car came with a hefty $1900 bill, so the HG option sure sounds prefereable in terms of cost and judging by their thread the results posted in the dyno section etc......
https://www.sau.com.au/forums/topic/401738-madgts-go-boom/#findComment-6383715
I wouldn't expect quite as good of a result as the dynosheets in the hypergear thread as his test car has a fresh engine and an aftermarket exhaust manifold.
Having said that they will produce good numbers for the cost!
I would worry about making sure the engine is all good before thinking about buying a new turbo to stick on it.
https://www.sau.com.au/forums/topic/401738-madgts-go-boom/#findComment-6383747
Will be sending the turbo to Hypergear in the next day or two. Seems that for the cost you can't go wrong.
I'm not chasing horsepower, to date it's been running std CPU, 8psi, around 165rwkw with FMIC, exhaust and suspension mods so any increase will be noticable.
I have a decent GTR fuel pump and an SAFC in a box somewhere so should be able to get somewhere around the 210-220rwkw before the std injectors max out.
All assuming there is nothing major wrong with the engine.
Z
https://www.sau.com.au/forums/topic/401738-madgts-go-boom/#findComment-6384346
The results I've posted from standard high flows are actually received from other customers. All the turbos are exactly the same how ever the results are bit of a mixed bag depending on various of factors.
After high flowing, contact Toshi for a ECU remap and get the best out of factory AFM and injectors, or just leave it on 10psi, which still makes a gain compare to a factory turbo.
https://www.sau.com.au/forums/topic/401738-madgts-go-boom/#findComment-6384585
I wasn't bagging your stuff stao, I'm happy with my turbo.
What I meant was don't look in the Hypergear thread at the dyno sheets and see that someone made 260+rwkw on standard highflow and expect the same number because it's all dependent upon individual setups.
https://www.sau.com.au/forums/topic/401738-madgts-go-boom/#findComment-6384721
  • 1 year later...
Just going through some old threads and noticed that I never posted an update. Better late than never.
Went with the HG rebuild/highflow option. Stao's service was A1 and the turbo was back in my hands in about a week (Syd-->Melb-->Syd).
The FMIC and plumbing was removed, cleaned, checked for damage, and reassembled. Throttle body also checked and cleaned. All good so far.
Engine was checked for any damage, plugs removed, visual inspection all ok. Looks like the FMIC caught all the busted compressor wheel bits.
Installation of the turbo and oil lines went as expected, left the heatshields off in case I had to go back in later. Removed the standard boost valve and replace the wastegate actuator with an R32 10psi unit.
Also stayed with the factory dump for now. Front pipe back is 3" - 3.25" - 3.5" and I have a 3" bell mouth dump/front to install later if required.
Inspected and cleaned the AFM - this would have been the reason for not being able to maintain idle.
Rechecked all fittings, filled coolant, replaced oil/filter. Rechecked all fittings again - to be sure.
Finished beer, crossed fingers, primed fuel pump and fired it up.
Kicked first go and ran a smooth idle.
That's pretty much it. I've been too busy/lazy to sort out the SAFC so the factory CPU is running 10psi on the standard pump and injectors. Feels stronger all through the rev range but there is a noticable lag (about 500rpm) before boost comes on strong. This was expected due to the highflow and would improve slightly if I install the bellmouth dump, install/tune the SAFC, and adjusted the timing a bit. It's nothing I can't live with.
MADGTS has returned to it's daily duties of getting the kids to school and me to work every day. Still as reliable as I could ever want.
Just kicked over 208,000kms and it's still the best car I've ever owned.
Cheers,
Z
  • Like 1
https://www.sau.com.au/forums/topic/401738-madgts-go-boom/#findComment-7196804
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
