Ok, update.
I've received some payments, so thanks very much to those of you who forwarded so quickly. :thumbsup:
I'm currently painting (and trying to dry in cold conditions :rant:), so we should be on track for a mid week post run. This will hopefully see everyone braced up by the weekend, or very early next week.
Thanks again for your support, and if anyone else would like one; I'm planning another run in around 2 weeks.
You can already get the Freeway Dolphin ones, and they do stiffen up the front quite substantially, but if you plan on running a plenum spacer there isn't anything available.
If you were going to get something, you'd have to get it to go behind the plenum. There's a little bit of room back there, but not sure if you could design something stiff enough with that many bends?
hey dale,
Totally off topic but how bout underbonnet strut brace. Would you be doing one or a group buy of these in the future?? If so im in...
^^^^^This.
The issue ends up being able to get enough stiffness when you applying the forces to the strut tower from so far back.
All of the reading I've done into Double A arm suspensions, suggests that they don't benefit from strut braces in the same way that McPherson strut style set ups do.
Because of the action of the suspension; the forces tend not to push the strut towers toward each other in the same way as a McPherson strut set up. Not saying that there isn't any benefit (there obviously is)just that the improvement is much less apparent.
Also, I can't really see a way to do it without tagging back to the firewall; which I'm really lax to do. I don't imagine many people are going to want to drill holes in their firewall to fit a strut brace.
Also the degree of complexity, and the number of parts; starts to push the price past what people are prepared to spend.
Edited by Daleo
I don't think you would significantly notice the strut brace in isolation, but when you pair it with the sway bars, coilovers, etc, it makes a difference.
Mine turns in significantly better than a number of others, and that was before I changed all the bushes, and before the under body bracing. It feels unbelievable, and I've had guys drive mine, and be passengers, and they can't believe the way it changes direction.
Sure, its no MX-5, but it's about 800kg heavier, and its designed for people who actually have friends/a life.
Just picked up my "Super Deluxe Cool-Style Spec Daleo Chassis Brace" from the post office! :woot:
I think I'll be doing some installation tomorrow morning...
Nice one mate; Auspost finally understand they must deliver MY parts the fastest. :yes:
Have fun mate; let me know what you think of the improvement!
I must say, this is simply and utterly
FANTASTIC!!!!!!!!!!
All of 10 minutes to fit it including jacking up the stag
Mine is completely standard apart from some really soft Japanese coil overs which came with the car, but my god what a difference it makes, confidently turns in, very noticible
Great work Dale ;)
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
