DRIVELINE
STILLWAY (japan) RB24DET Stroker
GTR crank
GTR rods
Custom HKS pistons
Engine block -unknown mods
Solid head conversion + unknown mods
274/274 cams
JUN Adjustable cam gears
850cc injectors
nismo fuel reg
HKS twin spark ignition system
BOSCH 040 internal pick-up
BOSCH 044 external feed
2L surge tank
GATES racing timing belt n new pulleys
standard coil packs
modded factory plenum
3" mandrel exhaust turbo to tip
custom intercooler piping and intake pipe (big G)
all internal mods are unknown as motor was built in Japan by STILLWAY company
Trust mid-mount twin scroll manifold
Trust T67-25G 10cm
Trust 48mm ext gate
OS Geiken 3-plate clutch
RB25 gearbox
custom tail shaft
standard R200 4.3 LSD -welded
standard 6bolt s13 drive shafts
Cooling
52mm alloy radiator
2x Maradyne 2350cfm each fans
B&M supercooler oil cooler
perma-cool relo kit
Standard ECU re-map by DR DRIFT
Power: 350kw@21psi on Powerplus 110 race fuel
Electronic
5 gauge AUTOMETER custom dash
-oil psi
-oil temp
-boost
-water temp
-3 5/8" rev tacho
switches for ignition, start, fans etc etc
Body
widened front guards
rear guards chopped
30mm widebody skins
topstage rear flares ontop of widebody
BA XR8 GT bonnet bulge
2UP headlight clear lenses
MARS side indicators
MARS 180sx front bar indicators
URAS N+ aero front bar
s13 aero skirts
Wheels
SSR Viennas
17x10 -19 (F) 215/40/17
17x10 -39 ® 235/45/17 (with 20mm 4->5 conv spacers)
skids: 17x10 D1Rs
Suspension
HKS HyperD fronts 10kg springs
TEIN HR rears 6kg
Adjustable caster rods
HEYMAN knuckles (troy)
GKTECH lock spacers
alloy cradle lockers
Interior
RECARO SR3 drivers
whatevers available on the day passengers seat
SABELT 3" ratchet harness drivers
SABELT 2" passengers...meh
back seats
rear seatbelts LOL
*soon to be all removed when i can F$%$Ked*
car is still in development stage as been building for last 3yrs and only seen 2 track days since
cbf writing up a whole story on the car guys so heres a picture story
where it all began as a CA18DE here shown jus with coilovers n wheels
removed bashed doors n chucked on doors from my old bent s13 n a bit of nismo/garden edge love
went reverse panda
at this stage it was CA18DE+T with a full trust TD05 kit...2 weeks later blew the headgasket so freshened up the motor chucked some JUN Cams in n was ready to go back in
then the RB24 popped up for sale from my mate, whom brought it down in a 32 drag/wangan car from japan was making 370kw on pump98 with a TO4Z with massive boost leak n coil packs cutting down
so the CA got ditched n then started the long n draining story of this silvia build
pictured here with its first turbo setup...HOLSET HX35W of a diesel truck engine
new fans n radiator
just b4 calder drift attack
ummm...dont ask
new look for matsuri n more rear offset
love my dash...
n finally....
this is the exact same engine from the s15 in the very popular youtube video lol
  • Like 1
Great first post for a build thread - if only the rest had all that detail and information, well done.
This car would be a riot to drive too, love it
thanks bro yer it is a handful n loves wide open throttle :)
wow , so is there anything left to do to the car apart from taking trim out?
pretty much only thing left...left the trim in there because initial plan was to keep it a street car but lost my licence too many times n thought otherwise
Interesting car mate, can I ask how it feels with the spring rates you have? Seems a little odd. Nice build though!
thanks bud
car feels stupidly quick, i like more of a soft setting to maintain full traction under full throttle even my front dampeners are on level 2 out of the 12 available lol
i still gotta get camber arms n toe arms for the rear n wind it out to about +.05 camber then just hold on for some stupid high speeds lol
  • 3 years later...
*EDIT*
for those interested, this motor took a turn for the worse after not even 3 track days, at calder i broke the oil pump when i went to clutch 4th due to a very early gear change on my part...the force of the 3-plate clutch pushed the crank straight thru n1 oil pump ending my day
however we pulled the motor down realized it was a godsend, the bearings were very close to be needing to be replaced and the crank was unharmed so a full overhaul was decided
also to those interested that was expecting a full house list of components myself included, well a surprise was in place
internals:
STOCK crank
STOCK rods
STOCK toyota piston
head:
STOCK
cams:
still unknown duration and lift
injectors:
mazda rx7 550cc
headgasket:
tomei(assuming)
oil pump:
n1
we were so shocked at how such a basic modded motor could put out the power it has done
here's a list of upgrades that will be going in/around the motor
ARP head studs
ARP main studs
ARP conrod bolts
TOMEI 1.2mm head gasket
BOSCH injectors(most likely 1000cc)
REIMAX oil pump gears
LIMIT bigger sump with tomei baffle
LIMIT oil breathing system/can
LIMIT surge tank
044 x2
SPOOL head drain kit
TD06H-25G 10cm turbo
TURBOSMART PRO-gate
MICROTECH LT12 ECU
and since scrapping the track s13 the motor will now reside in my daily driven R32 sedan
Edited by UNDR8D MOTOWORX
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
