Yeh he complains but he kept the stock throttle body for one , with his upgrades there is no way he shoulf still be running that..... and yhere is also someone in that forum sayin he got quicker spool, better response, a minor hp gain and no bleed off at higher revs ....... And there is no dyno sheets anyways , thats not results btw
Plazmaman told me that the std throttle body is fine for my power (TD06-20G). They said a throttle body would help improve performance further but they understood why I had reservations about spending more dollars given the results I was getting.
Plazmaman were great to chat to...they returned calls promptly and were helpful with things I need to check but I am about 90% sure they arent issues as I had already checked them all as part of the original install. BUT, I will be trying it once I get my other car back on the road.
Give it a nudge, will be interesting to see what results you get. I am making over 300rwkws now out of my RB20 so if there is something that will help make it it a little easier with less then 23psi etc then I am willing to give it a try. I still have Poncams laying around which are getting trialled after my next track day
...oh and for what its worth part of the reason I keep my engine pretty basic is that I happen to know a guy with a Gibson R31 GTS-R and its real interesting to hear all the things they tried and ended up with to end up with the 420hp odd that they raced with and likewise my tuner is a fan of a lot of std gear on the engine for a responsive street/track engine combination
  • Replies 112
Wow this type of stuff pisses me off, I know the guys at Plazmaman well I go there all the time and they deserve every cent of what they charge. The amount of r&d that goes into their gear is ridiculous and they will not be satisfied until they are sure it is the absolute best and cannot be beaten. For someone to come along and steal their design and brand it as there own is immoral and wrong, I have seen first hand the number of intercoolers they have in the scrap bin because they weren't happy. They looked fine to me but they simply didn't meet their strict quality control. Buy off the guy who put the effort in to getting it right!
One thing people are forgetting or not considering is that whilst the Freddy manifolds are cast these Plazmaman knock offs are welded and it pays to be prepared to take the thing off at one point and weld up splits. You hear of cheap welded alloy manifolds splitting and it's my guess that it is going to be worse these days with E85 and people throwing more boost at their cars
The 1JZ engines we have here run 60 psi boost and 150-200 shot of gas and don't have problems with the custom plenums that are on them. At the end of the day it all comes down to whether the person making the thing knows what they are doing. Any wanker can weld a box up and call it a plenum. Making it work and making it quality are two totally different ball games
please oh please sent me the details of said 1j's!!!!!
1. VR Commodore Ute - 1JZ (fastest and quickest 1JZ in Australia - currently doing 9.1 @ 153) Owners name is Derek
2. LJ Torana - 1JZ (quickest/fastest manual 1JZ in Australia - 10.3 was his time with the manual I believe but he put an auto in and now does 9.6 @ *edit* was 147mph) Owners name is Danny
Photos of the commodore are on my Facebook but the Torana is on Youtube on EFI's page
http://www.facebook....14465228?ref=hl
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
