anyone else eat at the Ultimo TAFE? you can book into there restaraunt for a really nice meal- costs about 1/4 the price youd pay in any other establishment. TAFE butchers are also a great palce to buy meat from.
La Perla- Gladesville, Victoria rd- Great fresh seafood, awsome Gonci with crab meat sauce, and fresh tuna carpaccio entre is amazing ( i usually duck in for just a serve of it) Not bad priced for what it is really- entres about $20 and mains $30
Good Cafe if your in balmain- Hangrys ( middle eastern breakfast) foul, Grilled halomi, Kofta, Baked eggs ect.
OR
The Bean- Best one on the strip, and ive eaten at them all. Eggs Benadict are quality as.
Both on Dalring street.
WAATTTT?
which Hurriances did you go to? the one in Bondi is better, always go PORK ribs with extra basting sauce. Don't get any other, they're boring,.
ribs were good, but more or less the same as outback steak house in penrith.
where they are cheaper.
Everything else is char grilled.
I farking hate char grilled.
missus got chicken, couldnt eat it because it just tasted burnt.
my steak was the same.
it was the darling harbour site.
because they have n00bs cooking at Darling Habour, you must go to Bondi (hotter slarts working too) haha
anyone built their own woodfire oven? I want to make pizzas with a woodfire oven......
Nope, But i use my Nono's for bread & Pizza. Takes a bit of prep to heat up, Clean ect But pizzas litrally take abour 2 min to cook.
Pretty much means you will never use it as much as you think you might, I useally put aside a day once a month for a big bread baking batch. Anymore then that and its a real chore.
look into Komado ovens if you keen, There great. or you can get soem pretty decent woodfire oven kits for about 2k.
Edited by sydking
yeah i want to build something similar to that, basically just bricks and crap.
but maybe a stupid question, regarding his oven: WHERE DOES THE FIRE COME FROM!?
I derno? maybe ask him.. then ask him for a RB25DET manifold for you and I too HAHAHA
2k!!??!?! helllllll no i dont even have a 34 , i ain't buying an oven for 2k....
hahaha. sure. not.
Hourani's in Rhodes has awesome leb food!
how awesome!?
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
