My question would be if cars with minimal mods are doing 6 second flat (or under) 0-100km/h, then why are the 1/4 mile times not displaying that. If your doing a 0-100 in 5.9, then I would have thought the quarter would be a lot faster than 14.6
Example- humor me.
03-06 350z. Accepted to do a high 5.# second 0-100. Does a quarter in around 13.6 to 13.9. Stock.
Anyway, just my opinion. They might be going faster than I thought.
See what "the stag wagon" comes back with!?
That's because they're not doing sub 6 sec 0-100 times, lol.
I have no idea if the Pocket dyno is accurate. I only used it because a) it was free & b) a reasonable form of comparison. It tells me that I dropped ~1.5 sec from one test to another, but in the real world I could have dropped from 5:00 minutes to 4:58.5 (sic).
Hand timed runs or phone apps are useful but not a proper comparison across cars/driver/location. Need a drag strip or other fancy electronic timing for that.
Yeah, it is debatable. And its all been done before. Some people would remember the M35 vs VE sportswagon thread, where a road test claimed that a stock M35 would do a 13.5 quarter, and 0-100 in 5.7 secs. lol- I'll buy that one!
Have to strap on some high end accelerometers and get a real figure if we want to end the debate. Really, does it matter? We have a good range of 1/4 mile times, and hopefully some really fast ones too once Scott gets his back together, and sky^rit as well. So we can compare them, and there is no error or subjectivity with 1/4 times. :)
Went on u tube found a 2002 ar/x in Russia doing a 0-100 showing the speedo dash only so being bored I did 10 stop watch times on it and got an average of 6.5 it sounds about right. Giving the amount of n m these cars have.??????
awd does count for a fair bit on 0-100, but not so over a 1/4m. My s1 c34 0-100 started in the low 7s std, and did a 5.99 before it went pop, using a HKS hard wired timer! Will see with the new motor, low 4s hopefully?
With a highflow the 0-100 times will usually be slower, that is assuming both turbo's are tuned properly and run the same mods. It's only past 50kph that mine would start to wind up and by then the stocker would be 2 or 3 car lengths in front.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
