What about sugarloaf and a BBQ??? Just throwing it out there, take it or leave it!!!
Sounds like a good idea mate, but maybe not as a first one, as I believe it may be hard to get the exact numbers for food etc.. Probably easiest to just to the pub, people can eat, or get a beer or whatever they want.
If there is enough interest, we can probably go up sugarloaf after the meet I guess?...
Ok Sunday July 8 is looking like the favored date so far.
Yeah as Anthony said, the first one will just be an informal meet'n'greet sort of thing so we know who each other are etc...... But the sugarloaf idea is definitely one to take on board for a later date!!
I guess the plan would be to have regular catch ups eventually with say a monthly Cruise which we have already had a few suggestions for which is all sounding pretty damn good!
July 8 is good for me, ill lock it in for now... Car or no car i will be there BUT if its not done by then i will have serious issues LOL
Going for a run with jarrad this afternoon at around 4.30-5 to take advantage of the nice weather.
if your keen to come along let me know and can arrange a meet spot probably in broadmedow..
No can-do for me today mate, i have to go do a timing belt etc on a mates car :yucky:
Would have been keen but domestic duties call
Not cool at all :/
I got held up doing a freebie on a mates car, turns out its the worst timing belt ever due to Loctite and stripped bolts etc.... Dodgy mechanics!!! :(
On a positive note guys, the car IS coming... JEM tell me that Adam is working in it today and that if everything goes smoothly ill drive it home next Friday.... :D
haha i thought that after posting and re reading.
pleaseeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
No problem mate, thread now posted in the NSW events section.
Hope to see alot of people there.
as this is a newcastle specific section...
does anyone find newcastle nightlife......well....just crap now?
Absolutely! I don't even bother with going out anymore... But I'm getting too old for that sh*t anyway :P
    • Did some FASTing ...got the impression that the actual part# was a moot point ; seems all of these hardlines for coolant are discontinued/NLA... like, I take it you're after the hardline that bolts onto to the manifold...that's NLA according to amayama & nengun .... ...just to clear up some confusion, they typically mounted the AAC valve to the intake manifold somewhere near a coolant passage, so the body of the valve heats up & holds it open when engine's up to temp - no coolant flows through the valve, it's a mechanical, thermal connection.
    • And now the bloody flapper is jammed slightly open. Lazy as all f**k in 3rd-5th (very hard to convince it to make much boost before you run out of revs), but will make 12 psi in 1st, which shouldb't be possible with a 5 psi spring and controller set to <10 psi. Methinks I'm lucky it jammed where it did, rather than fully closed. It's actually a well weird situation. Careful examination of what's happening in the back of that housing when the gearbox comes out and all the other stuff (injectors, AFM retune) is supposed to be done, next week.
    • The powder coating came in at $250 EACH. The TRX rims got a coat of clearcoat on the outside only.
    • Bit wet, but YUMMY
    • Keeping in mind that I am currently getting flat 10 L/100km on my RB25DET, which means >>500km/tank. I would test this car for vacuum leaks, check codes and AFM signal with NissDataScan as D says, check plugs, do a compression check while they are out.
