I wouldn't worry to much about the upgrades Anthony,
No ones going to overtake you, they would ruin the view - your car is just too goodlooking.
Matt, It sounds like that dyno reading has just about made your day, if not year.
Haha nice one, cheers!
Anyone going to the low down showcased this weekend in Sydney? was thinking of organiseing a cruise down, but because my car is entered in the rooftop, I may have to get there anywhere from 9-12 I think, which is a fair bit earlier than the 1pm start! My time slot isn't confirmed yet though.
Will be heading down to Sydney on Sat but not sure what time yet
Melisa is doing a fundraiser on Sunday at Windsor and taking the car down to put on display with a few other classic cars etc
Oh and take it easy on the roads today, was applying some right foot coming out of a roundabout with a bike in front of me and traction control took over. Gutter was looking close at one point til the application of some opposite lock.
Hey guys, random news....
My neighbour just acquired on of those new guard roller thingys and said if i had any SAU mates that wanted to try it out they can do it at my place with our heat gun and guard roller for $25 (cover maintainance and power etc only)...
PM me if you want more details, saves doing it the old fashioned way... :D
Not sure if that helps anyone, but in the spirit of SAU i thought i would chuck it out there ;)
Some more random news
Just finished pressure washing under the car and painted the calipers and rotors while I was at it
Used an old pad I had in the tool box to clean the paint off the Nissan logo and they look all nice again.
Was sick of looking at the shitty calipers and rotors
Pics of said news ;)
I forgot about the vaso/grease trick but the pads semi polish as well
Can't post pics but can text them if I had a number to send then to
If your not coming on the 8th send pics to 0434353292 mate, or just a g'day and we'll catch up... If anyone has mechanical issues etc let me know, I have a minor workshop slowly setting up so I can help others, and if it's anything tune related etc I'll recommend the Jez ;)
On an unrelated note, I am so excited about my car!! Power figure was one thing but seeing the dyno video made me so pumped!!! :yes:
^Nice one Matt..
For any one that was interested, i will be heading down to Sydney way before the the low down showcased starts at 1pm as i have to be there for 9.45am.... going to be a long day!
Forgot i commented haha.
Woo!!! Awesome!!!
I got some great weekends coming up!! Piss up in cronulla this one. Then meet up. Then Texi! Then nothing, then get keys to my house!! Thennothing for the next 5 years Lololololol jks.
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
