I will keep an eye on any beers (if its an open invite :) )
My car is off to Nathan @ Newcastle Dyno tomorrow for a tune and boost controller! Not expecting numbers much different than standard but hoping to get a mid range improvement.
Get mine back from Nathan tommorrow, am so looking forward to it, 2 weeks without it. Had a few issues that he's now fixed and also set the boost controller. Will post how it drives tomorrow. :woot:
When are yous guys going to have another R chassis circle jerk again....i mean meet/cruise and make all of us other people in "not real skylines" and other models feel singled out and unwelcome?
Because im keen for that sh*t!
Then set a time and place and see who turns up
Or get over yourself and stop holding a grudge
Hey all, just moved to newcastle ad i am after a decent auto-elec. If anyone has any recommendations and/or warnings that would be great, cheers.
Hi
What work do you need done?
Can't really recommend anyone apart from Nathan at Newcastle Dyno but if its a simple thing I'm sure someone knows how to do it
Hi
My power windows in my R32 are not working after an RB25 swap. I have tried fixing them but haven't got anywhere. Also my dash cluster is not working.
hey guys, havent been on in a while. garage should be started to be built on Saturday if martin ever delivers my stuff! :)
Awesome news mate! Mine is slowly getting setup too -
Looks good matt.
where and how much are those shelving worth? ive got some crappy wooden ones in mine atm that were there when i bought it.. want to clean it up and minismise the amount of shevling for more room.
also would really like to install a door onit as it only has the 3 roller doors atm..
Looks good matt.
Ummm you can get them from Office City over near Islington i think it is... Can get all shapes and sizes! They have an ebay store too which actually lists a lot of the pricing!
Will be a power wire not hooked up somewhere then
You can try tracing it yourself or ring around the lecos and see who sounds good
I really hope it is, as its a 5 minute fix, but i pretty sure its not. I have spent 3-4 hours tracing wires to try and find it and got nowhere.
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
