I was working on my R32 GTR and thought it would be a good idea to leave the cam cover off. Well I started it and all was fine until I noticed that the bolts on the cam gear were interfering with the Cas. I immediately shut the engine off and removed the Cas to find it very hard to turn and noticed the half circle from the cam had snapped off. Anyways I bought a new Cas and aligned the cas to the cam 100% correctly and now the exhaust pops but won't start at all. I'm assuming the timing is out but have no idea how this could happen. What do I do to get my car running again? Please help if you have an idea.
Thanks
same happened with my setup, i snapped the cam gear thing off, you just need to get the cams aligning with the marks, should be able to look in there with a torch and simply slide the cam angle sensor in where it would of match up and you'll be fine, the cas might need turnt one way more than before, so try again,
you must of just put it in on the wrong angle which has made the timing wrong.
make sure you space it right with the old seal from the cover.
Edited by SliverS2
Thanks for the help mate.
I've tried putting the cas on about 10 times everytime ensuring that it was going in right and still nothing. Even with the new Cas I bought, the cam has still got just enough of a lip on it so that the Cas only goes in one way.
I might try put the cover back on instead of using washers to space it and see if that does anything. If that doesn't help then I'm clueless.
i first did this with my old gtr when i left the cover off, you need to put washers between the CAS and CAS bracket otherwise it makes contact with the bolts that hold the cam gears on and will grind the shit out of the CAS
As well as the half circle in the cam, there is a set of teeth on the cam and the CAS that mesh together when the CAS is installed. So you can set it up about 10 different ways if the half circle is missing.
There is only one mounting position for the CAS that will allow the engine to start.
Thanks for the help guys. Doing a bit of research it seems that a lot of people have made the same mistake as me by not spacing the Cas out from the cam. I'll try different Cas positions tomorrow and hopefully I can get it started.
Did you set the timing after you put the CAS on?
Remember that once it is on it can still rotate left or right to adjust timing (like a distributor on an older car)
You really need to get a timing light and check the timing once the CAS is on. 15 degrees (middle mark on the harmonic balancer)
it really is tricky and be careful or you might end up breaking the cas like i did,
double check the bracket itself is on properly with the two dowels lined up and going into the holes on the bracket, tighten every bolt gradually and equally, use the mark on the cas to line it up,
you only need to use that black seal with the washers in it already, the one from the cover, and you should be right. :yes:
Edited by SliverS2
Well I tried to get it started today and have had no luck whatsoever. I'm not sure if the motor is full of fuel now or the spark plugs are too wet to fire but it just doesn't want to start. Really confused on what to do right now.
you might have the half moon 180degrees out, can you seen inside the cam gear part so that your lining it up properly,
Does the cas feel like it hits home , if its quite loose feeling it might be broken inside,
plugs will be getting wet too, but it should still start , try not to be cranking it for too long, it should turn over fast if its in the right spot.
Yeah there's a shiny half on the end of the cam that I'm obviously assuming is where it has snapped off. I've lined it up a million times now but still nothing. I'm starting to think I've bought a dodgy Cas sensor.
Yeah it slots in nicely and I've checked to make sure it's spinning when it's being turned over. You can also hear the injectors ticking when its cranking which would suggest that it is working. I bought it second hand off someone who had a spare for his GTR. I'm tempted to get someone to have a look at it as it's starting to do my head in as to what could be causing it not to start. Maybe there's a bigger problem but it's confusing because it was working beforethe tooth snapped off from the cam when I ran it with no cover.
CAS types sorry photos didn't copy but you can tell early one becasue of metal case and Mitsubishi logo later one by plastic case (Hitachi).
This is an R33 one (Mitsubishi) 23731 02U11 metal case
This is an R34 CAS -(Hitachi) 23731 5L 300 plastic case
I don't think the wrong one would engage properly with the drive on the end of the cam so if it fits ok you could just try reversing the wiring.
R34 CAS
pin 1 = earth
pin 2 = power
pin 3 = 1 deg
pin 4 = 120 deg
R33 Cas
pin 1 = 120
pin 2 = 1
pin 3 = power
pin 4 = earth
And making it easier basically showing that:
1 swaps with 4
2 swaps with 3
3 swaps with 2
4 swaps with 1
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
