  • Replies 124
Posted Images
thats it!. It will be like a Mclaren pitstop lol , It seems fine now, fuel pressures holding, and hasn't missed a beat since cleaning it, so hopefully it will be all good until I get the new pump on monday.
Luke are you meeting everyone at the ettomogah or heading straight to there, I ask because would you be able to bring the pump as a 'just in case" for me?
So Ettomogah Pub meeting point is a go!!!!!!!!!!
See you all there!
Bob.
So.... for those who dont know exactly where Kravings is.
Bells Line richmond
Head towards the mountains
Over the river and through North Richmond
Up the hill and continue to Kurmond
Passed the Restaurant that is all fenced off on the right and its litterally 20 seconds further up on the right.
If your one of the first there there will be my black and grey HR31 GTSX and GregR31's.... R31 which is burgandy and black.
Hope everyone gets there safely and we shall see you there.
See you all there!
Bob.
Thats where I'm heading to.
Took the car to the mechanic this morning, and he found the TPS and base idle were out of adjustment and a faulty o2 sensor, so he seems to think the pump is ok and it was the ECU going haywire , so I've changed the o2 sensor and it seems ok touch wood.
We will obviously be inside for lunch and in your own cars, possibly with heaters for the cruise lol. I still dont know where we could actually cruise to for some pics or a chat but we can discuss this tomorrow.
19 confirmed and its booked under Liam Ford.... Not Skylines Australia however for those who dont see this I'll word up the Kravings staff that some may say its SAU...
Thanks everyone and see you all tomorrow
not always obvious on the seating inside.
we thought we would have indoor dining in the pizzas in the mist cruise, that ended up being a COLD lunch....
and liam ford/SAU, same....
Unfortunately lunch is full. It was confirmed on Thursday so no spots left at the table.
Not sure what time we will be finished lunch and going on the cruise, possibly 2pm but depends on how quick we get food and everyone wants to leave. Feel free to come for the cruise tho.
RGB txt me on 0421799454 and ill let you know early morning if I can make the lunch or not, maybe you can take my spot and I come for the cruise.
Had some issues with the car which im hoping to resolve tomorrow morning.
sorry about this being last minute FordyR31, my front bar fell off tonight :(
Edited by extatic
Thank you to everyone that attended it was nice to meet everyone even I have forgotten ur names. Lunch was really nice as I expected and good company to boot. Very friendly and a nice easy cruise and coffee to finish off.
Thanks again and Im glad everyone enjoyed themselves.
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
